Old 10-22-2019, 04:50 PM
gto19's Avatar
gto19 gto19 is offline
Default 67 rear stainless rocker removal
Hey guys
How do you remove the stainless rocker behind the rear wheel ? I see the three screws that need to removed.
Old 10-22-2019, 06:25 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
After removing the 3 screws ..... gently push up on stainless moulding.
Old 10-22-2019, 08:11 PM
gto19's Avatar
Is there clips behind the rocker or something?
Old 10-22-2019, 09:21 PM
BOB VIDAN BOB VIDAN is offline
Yes, clips. Top of the molding hooks into top of the clip. Clips mount over studs on the body. VP's are always a little short with their explanations.
Practicing social distancing for 65+ years
Old 10-22-2019, 09:33 PM
gto19's Avatar
Thanks bob
I’m sure it will be nightmare trying to get off . Any tips ??
Old 10-23-2019, 07:19 PM
gto19's Avatar
Came off super easy
Thanks for the advice
ID:	522785   Click image for larger version
