Old 10-27-2019, 10:22 PM
marxjunk marxjunk is offline
Default 425A trophy motor
I need some help..new territory for me..Ive never owned an older 389 and now have one..I want to use the block and rotating assy, its a stick motor...can some one tell me or link me up to what it takes or if its even possible to run a 65 up top end...
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 10-27-2019, 10:26 PM
tom s tom s is offline
Are you going to use it in a 61-63 tempest?The only issue for the top end is what year heads you use on your early block.The valve angles were changed in 67.Tom
Old 10-27-2019, 11:34 PM
Yes a 63...
I need to pull it apart i guess
Mark..
The Goat whisperer
Old 10-28-2019, 09:12 AM
Radman's Avatar
Radman Radman is offline
Newer heads should bolt to the block. One note 63 and older heads have the 12 bolt intake, the 64 and up should be 10 bolt intake manifold.
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
Old 10-28-2019, 01:12 PM
Rocco Testa's Avatar
Rocco Testa Rocco Testa is offline
64 Blocks use the older 12 bolt manifold and it's different that the (65-79) manifolds? (61-64 )That said if you want to run newer open chamber heads or new Aluminum, heads you really need to do a piston change for the valve angles. I know some guys run the new heads on the older blocks without the piston change but I wouldn't. Push rods are different and all valve geometry will be off. In my book its a No No.
Old 10-28-2019, 02:01 PM
Just run 65-66 heads AND intake manifold and you will have no issue!Tom
The Following User Says Thank You to tom s For This Useful Post:
Old 10-28-2019, 04:58 PM
Tom is correct, but you will have high compression and may need more then 93 octane fuel. You could also get custom head gaskets to lessen the effect of the lower octane fuel. My 64 with the 716 heads will just about ping with 93 plus booster. If your on the east and north coast you can get 93 fuel. If your on the west I don't think its available but I maybe wrong and I'm not sure about the south.
