motor plate/ crank trigger
What up guys, I ordered an All Pontiac front motor plate for my junky ole firebird friday so i havent got it yet, just curious how ya guys that are using crank trigger are mounting the bracket and sensor? My theory is that frank at All Pontiac said the plate is 1/4" thick and the sensor bracket is bolted where the front plate bolts up, so this means it will push the sensor out a 1/4", so me and my engine builder discussed this situation and came to the conclusion that if we mill a 1/4" off the sensor bracket then everything will stay exactly where it is at right now, we do not have to move the sensor around due to timing adjustments will be made through the power grid system..... thanks in advance for all replies and photos or suggestions......
See the pictures on our Web site. Dont Panic. It will be easy mount.
Bob C. Quickest, Fastest, Best selling Pontiac Aftermarket Block IA II and Tiger Heads Boss Bird Funny Car Best pass to date 08/06/2016 6.027@231.64 Allpontiac Big Chief Aluminum Engine Block http://www.AllPontiac.com |
See the pictures on our Web site. Don't Panic. It will be easy mount.
I slotted the plate and removed the 1/4"thickness from the bracket. worked well no probs.
X2...
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion Last edited by Probird; 01-08-2017 at 10:28 PM. |
The Following User Says Thank You to Probird For This Useful Post: | ||
