As a non-Pontiac aside, my current project, a 1956 Packard "Panther", "What if?" car is a restomod with a hopped up Packard 374CID V-8 (2x4 intake, HC-01 size hyd cam and headers), and should put out about 400HP. However, where I live it can be 115F in the summer time and there's a long grade from 2,700ft to 5,300ft to get over the mountain pass to Las Vegas. Therefore, fuel vapor lock is a problem in that situation, as is driving in stop-go traffic in Las Vegas at the same temperature with A/C running and probably 130F asphalt road temperature. This is exacerbated by the 10% ethanol in the gas we can get out here since ethanol has a lower vapor pressure than gasoline. All these conditions being considered, that's why I duplicated the fuel pump, fuel feed, regulator and fuel return sizes from my TurboForce bird onto my Panther. Just another situation to consider on a non-drag, but high performance car that is not FI. Last edited by Craig Hendrickson; 06-29-2016 at 10:19 AM. |
-8 is 8/16's or 1/2"... -10 would be 10/16's or 5/8"...
1969 GTO, 3370 lbs, 10.5” tire... 07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads |
AN (Army/Navy) -8 hose is equal to a 1/2" tube. Tubing is measured by the outside diameter. Depending on the wall thickness, the inside diameter is smaller, so a AN -8 hose is less than 1/2".
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
Take a really thick tube to make -8 to equal 3/8's...
Yeah...pipe which is also measured in ID. 3/8 iron pipe is approx 1/2" OD iirc.
Cheap AN fittings can also have much smaller ID than the size they should be. |
-8AN is usually listed with an inside diameter of .430" whether tubing or hose, and that's a little less than half way between 3/8" and 1/2". (.375" & .500"). Throw in some of those more restrictive -AN fitting inside diameters and a few bends and we're close to the flow of the smaller diameter.
I think you guys are stressing too much?
What you are really after at the end of the day is proper fuel pressure and fuel flow to the engine under all conditions not just maximum HP conditions. If you can't set the fuel pressure properly to 6 psi because the return line is too small and even with the adjustment screw is backed off the pressure still reads 8.5 psi, you have a problem. Course I have seen people BS on that deal with "It won't make a difference" but a Holley guy will tell you otherwise. With the bigger line and the lower fuel pressure at idle NOW you can adjust the pressure screw to give you 6 psi fuel pressure at the needles and seats as Holley would like to see. Some pumps just move too much fuel for the average fuel return line diameter on typical installations. Tom V.
Was under the car a little yesterday with -10.man that stuff looks big!
That's what she said. 😉
Sent from my XT1254 using Tapatalk
Giving To Others!!! V.P. Pioneer Valley GTO Association www.pvgto.com 67 Lemans 455 best et. 12.023@ 111 mph LVD 9/2008 68 GTO H.O. in progress? |
Are you planning on running all braided hose to the back of the car?
Yes I have the -8 in TPFE so it is a little smaller. Can't find -10 in it and snaking the rubber past subframe connectors and potential tailpipes will be a job.
Is there aluminum -10 ?
Yes...5/8 aluminum is available. I ran it on my other GTO for a return...
On my car I have a VoluMax Holley white pump rated at 250 gpm. It has a #10 outlet and a #8 return opening in the billet base. I contacted Holley tech and they said to run the return from the pump back to the tank, not needed from the regulator. And, that # 8 return is fine since it has a much shorter run. Seems strange that they would make the pump with a smaller return opening if it needed the same size as the supply, as most are suggesting.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
John good article there. They have my 250 gph as at the max for -8 return, and my 695 HP close to the max for -8 feed.
Also showed a second dead head regulator at the carb after a return regulator on the drag system-interesting.
#38
I think so to. I got out the popcorn.
#39
Well my 78 TA I had to keep morphing the fuel system as it got more HP as it had starvation issues until I ended up with my current system. a 150 HP more motor I want to do it right the first time.
#40
Stressing? There is some good information is being shared in this thread, especially why a larger return line is the correct way to plumb a fuel system . Additionally, one will understand that fuel hose & tube measured by the AN system is not necessarily ID.
