KRE D vs IRON D Ports
Do Kre d ports need longer pushrods vs a Iron d port?
A new best of 9.135 @ 145.41 71 Lemans Sport. 72 Lemans Sport. |
Call them and check, but I think the standard 9.130" works.
Regardless of what is posted, I'd STILL check for myself.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust My webpage http://lnlpd.com/home |
Like Lee said check them- too many variables different lifters have different cup height, milled head/decked block affects it even different brands of rockers affect it.
I needed some 9.30 pushrods with my KRE d ports.
Wont the type and make of lifters matter on pushrod length?When I went from Isky solid rollers to comp hyd rollers I needed a 1/2in shorter push rod.Tom
Rocker arm brand changes, change the length too .
My Half AN Injun..... |
Check the length!Back in 2009 I was about to order my pushrods,I compared length with a fellow member who had the same cam,lifters and so we thought the same heads.We both spent a few hours trying to figure out why our calculated pushrod length was so different.It turned out my heads were setup different with a shorter valve.At the time we both had SD 290 cfm KRE heads.Don't assume anything!
