Old 06-27-2022, 10:16 AM
scott70's Avatar
scott70 scott70 is offline
Default rhoads V max lifters
If you set the clearance at .010 are you pretty much eliminating bleed off and making them act like a standard HFT or how does that work?
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 06-27-2022, 10:40 AM
Jay S's Avatar
Jay S Jay S is offline
There is still quite a bit of bleed off at .010”. There is actually more bleed of going from zero lash to .010”, than their is going from .010” to .020”. It is because there is more acceleration as the tappet gets pushed further open. I like running them at .010”, they are quieter.
Old 06-27-2022, 10:45 AM
77 TRASHCAN's Avatar
Jay, I believe you have used the V-Pro lifters, also???
Got any words about them???
Shut it off
Shut it off
Old 06-27-2022, 11:56 AM
Jay S's Avatar
The only time you would really require a Vmax over a Vpro is if your are running a lot of lash, .030” or more. The last several sets I have done were Vpro. I think the only difference is the Vpro have a thicker shim. With the lash set same I can’t tell a difference.
The Following 2 Users Say Thank You to Jay S For This Useful Post:
Old 06-27-2022, 01:22 PM
scott70's Avatar
Ok...I noticed in the instructions on the vmax that if you are experiencing detonation that you can tighten them up to no less than 010. I think I set mine originally. 015.
Old 06-27-2022, 01:44 PM
Jay S's Avatar
If there is an issue with detonation and the combo needs as much action as you can for low end manors or vacuum for brakes tighten the intake only. You can go down to .005” on the lash on the intake, can even zero lash them cold if you want. Set only the exh side wider.
Old 06-27-2022, 04:43 PM
Jay S's Avatar
If the lifters were set cold that .015” is probably pushing .020” hot. People often blame the oil viscosity for the change in noise when the engine gets hot, which is true for the original Rhoads. Because of the way the lifter is shimmed, with the V type most of the extra (sowing machine sound) noise comes from the expansion rate of the engine increasing the lash once hot. Zero cold on a Vmax is more or less the similar to .005” hot.
Old 06-27-2022, 07:56 PM
scott70's Avatar
Yes that was set cold. When I first start it up its pretty quiet for quite a while but after a while of driving I can here the sewing machine sound at stoplights. I run 15w 40 oil. Right now the power brakes seem to work good all the time. So I could go .005 on the intake and .010 on the exhaust cold?
So rotate until lifter is on the lobe base,,insert feeler between rocker tip and valve tip,,tighten until valve starts to open ,,tighten rocker stud nut set screw? Something like that. That is supposed to push the center of the lifter all the way down away from the top retainer clip. Easier to visually see with valley pan off but Im not pulling all that to have a visual.
Old 06-28-2022, 01:20 AM
Jay S's Avatar
You can go .005” on all the valve’s if you want.
Speedy way to set it in your case is just shy of a 1/4 turn down on the poly locks, should be .005” if your at .015” now.
Or you can go across each lifter, positioned on the base circle, apply pressure so it is bled down, with the only preload being the check spring inside the lifter (usually takes about 20 seconds of modest pressure on the pushrod to bottom the lifter) then insert the feeler gauge and adjust accordingly.
If you crank down the poly-lock to bleed the lifter it will mean starting from scratch on all the settings.
The only things different on setting Rhoads V’s verus setting a solid cam’s lash is making sure the lifter is bled down, and there is some spring pressure yet on the pushrod from the spring inside the lifter.
Old 06-29-2022, 09:27 AM
scott70's Avatar
I had a .008 feeler so I used that. Only ended up with a additional 1/8th turn though from where it was. Haven't driven it yet though. They must of been bled down already because with the feeler installed I would go just a little beyond where I couldn't pull the feeler out and waited for a minute and it never loosened up.
Old 06-29-2022, 10:05 AM
Jay S's Avatar
Yep, it sounds like they were already bled down. Where I have ran into needing to bleed them down was tuning a hot engine.
Old 07-02-2022, 01:42 PM
scott70's Avatar
Lash setting can be different to different people. If I'm setting lash at .010....I use a .010 feeler and make it pretty snug. I can still get a .012 in there but it's hard and a .014 pretty much won't go. How do you do it?
Old 07-02-2022, 05:17 PM
Jay S's Avatar
That described .012” to me.
Old 07-03-2022, 02:15 PM
scott70's Avatar
Going from 015 to .010 really quieted down the sewing noise at full temp after driving 50 minutes to a car show today. Didn't hear any pinging but then again my wife was with me so I drove normal. Did notice the car is more " rumpy" when trying to drive at low speeds...does a little bucking when driving a constant speed with low rpms.
Old 07-03-2022, 02:30 PM
Tom Vaught's Avatar
Boost Engineer
x2
Tom V.
Old 07-03-2022, 07:56 PM
scott70's Avatar
I did have a engine builder tell me years ago that if you can get the feeler in there that's what you got. But have witnessed other people not go that far with that statement.
Old 04-28-2024, 05:52 PM
scott70's Avatar
So obviously an older thread of mine. Checking lash on these max lifters today . Kinda weird I thought I set them at .010 but checking the very first one today I can get a .016 in there. Also my feeler gauges are actually wider than the wheel and the wheel sits below the rocker body. Doesn’t sound like it would be accurate. Really need a feeler gauge that's the same or a little narrower than the wheel so the gauge doesn’t hit the rocker body.
Old 04-30-2024, 04:19 PM
Jay S's Avatar
My experience with them is that growth happens quite a bit rechecking vmaxs.
Some set them cold and rechecked later when hot. If .010” was cold it probably is about .014” or more hot, and .016” cold is upward of .020” hot.
Old 04-30-2024, 07:18 PM
scott70's Avatar
I wrote this before looking further into it. The roller tip on the crower rockers sit below the rocker body on top but underneath where the roller touches the valve stem the roller hangs below the body. I thought my feeler gauge was running into the rocker body but its not. Also I would of swore I had set the lash at .010 but when I checked on a cold engine recently they were between .012 and .014. Running that m21 with 3.31 gears I wanted to possibly recover a little low rpm torque. So for now Im leaving the ones at .014 and loosening the tight ones to .014.
I find it hard to just go by feel. I could get a .012 feeler in there and feel snug. But if I took a .015 or maybe even a .016 and really pushed hard I could get it in there. I found it easier to check by actually doing what Rhoads recommends. I put the feeler in there and lock it down when i can barely spin the pushrod with my fingers.
