Old 07-23-2023, 08:56 PM
GoreMaker GoreMaker is offline
Default Alarm Door Trigger Wiring
I'm finalizing the alarm system wiring in my 1977 Trans Am. The alarm module has inputs for a ground door trigger and a positive door trigger to detect when the door has been opened. The way I understand the car wiring, opening the door releases the door pin in the jamb which creates a ground contact that allows the always-live wire to flow current through the dome and under-dash lights. Which wire on the alarm system should I connect? Positive trigger or negative trigger?
Old 07-23-2023, 10:23 PM
Bill Hanlon's Avatar
the ground door (negative) trigger
Old 07-23-2023, 10:25 PM
But doesn't that wire become live (+12v) when it gets grounded?
Old 07-24-2023, 08:14 AM
No, it is +12v when the door is closed and ground when it is open.
The Following User Says Thank You to Bill Hanlon For This Useful Post:
Old 07-24-2023, 09:25 AM
Thank you!
