Old 05-03-2008, 01:28 PM
weranc55's Avatar
weranc55 weranc55 is offline
Default Ram Air 3 spark plugs
I need to replace the plugs on my ra3 and they do not make the ac delco r44s anymore. Does anyone know a good substitute for that plug. I dont want to use the r45s. I think its to hot of a plug and gas is not what it was in the past.
Old 05-03-2008, 04:29 PM
unruhjonny's Avatar
I have found that the R45S or R43S work just fine.
The R45S was the plug that the 70-L78 was supposed to use (same heads), and the R43S was the plug designated for "high speed driving".
If you are considering not using a Delco plug, I put a fair ammount of research into equivalent plugs;
I will give you two alternate plug brands, but I personally don't like chamions, they always seemed cheap, and I have heard of more than one time where they admitted their heat ranges were way off. I like Autolites or NGK (I don't have comparable NGK numbers handy - PM me if you want them)
R43S = Autolite #84* = Chapion RJ-11-YC
R44S = Autolite #85 = Chapion RJ-12-YC
R45S = Autolite #86 = Chapion RJ-13-YC*
(* = I'm not sure these plugs exist)
I hope this helps!
1970 Formula 400
Old 05-03-2008, 05:03 PM
GRNMTGOAT's Avatar
GRNMTGOAT GRNMTGOAT is offline
Just went out and looked at my newly rebuilt stock RA3 motor, Paul S has used Autolite 85's, they must be OK ! Bruce.
1970 T/A RA3 #'s match.
Old 05-03-2008, 05:41 PM
weranc55's Avatar
85's it is. Thanks for the help.
Old 05-04-2008, 12:38 PM
giles's Avatar
giles giles is offline
If you can find a set of R43S they should work just fine. I have run them in a stock RA3 without issue. The area where "cold" plugs will cause issue is during winter cold starts (below freezing). The colder heat range is much more suceptible to fouling. In warmer temps the cold plugs are better for detonation avoidance, thus the "high speed driving" recommendation.
For almost everyone here, who I assume drives their cars on nice days, and does not slog through winter commutes in sub-freezing temps, one or two heat ranges colder than OE is a good choice.
Old 05-08-2008, 06:29 PM
briann briann is offline
I hope this helps!
Yes the ACDelco R43S plugs do exist. I just bought 8 of them today.
Old 05-08-2008, 11:38 PM
unruhjonny's Avatar
I wasn't wondering if any of the delco plugs existed, I think this is common knowledge...
I just don't know if the one champion or autolite coded plugs exist.
1970 Formula 400
Old 05-09-2008, 01:59 AM
ahhh ok....my bad....
I actually thought I had the coldest plugs in my engine and was quite surprised this morning when I found out otherwise.
Old 08-19-2023, 09:18 PM
tdavidl's Avatar
tdavidl tdavidl is offline
had my 71 400 rebuilt 5 yrs ago to RA III specs and autolite 85s. pulled a plug today to check gap and it was .026...can anyone confirm that gap for RA III 400 autolite#85?
71 Formula 400, Castillian Bronze, Saddle Interior:
https://youtu.be/cfEv-1vKc0k
Old 08-21-2023, 01:56 PM
Transamric's Avatar
Plug gap depends on what ignition you're using. A hotter ignition like a big cap GM HEI can take advantage of a wider plug gap of .045" to .055". But a basically stock points ignition will need to be narrower at .028" to ,035".
The Following User Says Thank You to Transamric For This Useful Post:
Old 08-21-2023, 08:39 PM
tdavidl's Avatar
thx TA ric...i replaced points with a petronix unit...wanted more reliable, lower maint ignition...so i suppose they matched the gap to this unit...was just curious as i remember back in the day my gap use to be in the mid to high 30s if i recall correctly
