Ram Air 3 spark plugs
I need to replace the plugs on my ra3 and they do not make the ac delco r44s anymore. Does anyone know a good substitute for that plug. I dont want to use the r45s. I think its to hot of a plug and gas is not what it was in the past.
Thanks |
I have found that the R45S or R43S work just fine.
The R45S was the plug that the 70-L78 was supposed to use (same heads), and the R43S was the plug designated for "high speed driving". If you are considering not using a Delco plug, I put a fair ammount of research into equivalent plugs; I will give you two alternate plug brands, but I personally don't like chamions, they always seemed cheap, and I have heard of more than one time where they admitted their heat ranges were way off. I like Autolites or NGK (I don't have comparable NGK numbers handy - PM me if you want them) R43S = Autolite #84* = Chapion RJ-11-YC R44S = Autolite #85 = Chapion RJ-12-YC R45S = Autolite #86 = Chapion RJ-13-YC* (* = I'm not sure these plugs exist) I hope this helps!
Just went out and looked at my newly rebuilt stock RA3 motor, Paul S has used Autolite 85's, they must be OK ! Bruce.
1970 T/A RA3 #'s match. |
85's it is. Thanks for the help.
For almost everyone here, who I assume drives their cars on nice days, and does not slog through winter commutes in sub-freezing temps, one or two heat ranges colder than OE is a good choice. |
I just don't know if the one champion or autolite coded plugs exist.
I actually thought I had the coldest plugs in my engine and was quite surprised this morning when I found out otherwise. |
had my 71 400 rebuilt 5 yrs ago to RA III specs and autolite 85s. pulled a plug today to check gap and it was .026...can anyone confirm that gap for RA III 400 autolite#85?
Plug gap depends on what ignition you're using. A hotter ignition like a big cap GM HEI can take advantage of a wider plug gap of .045" to .055". But a basically stock points ignition will need to be narrower at .028" to ,035".
The Following User Says Thank You to Transamric For This Useful Post: | ||
thx TA ric...i replaced points with a petronix unit...wanted more reliable, lower maint ignition...so i suppose they matched the gap to this unit...was just curious as i remember back in the day my gap use to be in the mid to high 30s if i recall correctly
