Old 06-21-2023, 11:03 PM
Catsteven Catsteven is offline
Default External regulator and alt getting hot with batter Pwk applied.
Hello , changed my generator to an alt with external regulator. I had the parts for some time never been used. Installed new wiring from info that I found on this web site. Batt Power to alt from amp meter other side off horn relay. Regulator number 1 wire to f on alt 2 wire to r on alt 3 wire jumped into hot wire to alt. 4 not used. Started and charged at idle 13.5 volts . Amp meter indicating a charge. Everything seemed fine except the alt felt hot.
I noticed that the alt and voltage regulator was getting hot with battery power. When I disconnected the negative cable I got a little spark like something was on.
Just doesn’t seem right. Any ideas thanks for any thoughts.
Steve
Old 06-23-2023, 03:13 PM
61-63's Avatar
61-63 61-63 is offline
Steve put this in the "street" section and you'll get a quicker response. Of course the moderators may just move it right back. John
Old 06-24-2023, 09:24 AM
Thanks John relisted in street section.
Old 07-06-2023, 08:59 AM
AC Delco regulator D631A, 3 wire regulator. Only one contact coil. no number 2 terminal alt return wire I believe. With out this wire what controls the regulator.
