Old 08-11-2023, 03:11 PM
69geeto's Avatar
69geeto 69geeto is offline
Default Parking Light Current draw
So, my 69 GTO is blowing the 20A fuse for the running lights. I check the load side and see .8 Ohms. (VERY low.. and all are LED bulbs). If I turn on the headlights, the resistance goes up to maybe 10 ohms (and the fuse will then hold). I've never seen anything like this one.
Any thoughts? Nothing has changed over the last year, and it just started happening.
Stu
http://www.CarShowSoftware.com
Old 08-11-2023, 04:16 PM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
Does it blow as soon as you put a new one in, or as soon as you turn the lights on, or just at random intervals?
Mike
Old 08-11-2023, 05:25 PM
69geeto's Avatar
Pretty soon as it's turned on. With .8 ohms or less, the current is hitting close to 20A. Just very strange that that resistance goes higher when the head lights are turned on. I may need to look at the light switch.
Stu
Old 08-11-2023, 05:44 PM
mzbk2l's Avatar
If the LEDs don't have built-in resistors, they may show almost zero resistance. If the headlights are still incandescent, do they add their resistance to the circuit when they're turned on? (Hence your higher readings with the headlights on.) The only LEDs I've installed (other than interior lights) are the daytime running lights in a 2005 Tahoe that liked to go through a bulb every month or so until I switched to LED. Those were Phillips and advertised as plug & play. I've never checked resistance in that circuit, but it hasn't had any problems in the 6 or so years they've been in there.
Mike
Old 08-11-2023, 05:48 PM
69geeto's Avatar
I'm sure the led's have built in resistors. I did check the resistance and it was very high (low current draw). They were installed over a year ago and all was well until last week. I'll keep plugging away. I think pulling the switch might help troubleshoot.
Stu
Old 08-11-2023, 07:16 PM
Bill Hanlon's Avatar
Bill Hanlon Bill Hanlon is online now
Trying to read resistance (ohms) on an active (has voltage applied) circuit isn't valid. The ohmmeter injects a small voltage into the circuit to be measured and gets real confused when other voltage is in the circuit.
The Following User Says Thank You to Bill Hanlon For This Useful Post:
Old 08-11-2023, 07:38 PM
69geeto's Avatar
I pulled the fuse and measured the load side with a fluke meter. The load side is in fact less than 1 ohm (way to low) which would draw 12 amps.. Ya, can't measure resistance with voltage applied.
Stu
Old 08-12-2023, 02:11 AM
Geoff Geoff is offline
Sounds like one of the LED lamps has developed an internal fault & is drawing excessive current, which is blowing the fuse. Remove the LED lamps one at a time to see if it fixes the problem.
The Following User Says Thank You to Geoff For This Useful Post:
Old 08-12-2023, 10:41 AM
And don't keep blowing fuses. Pull the bulbs one at a time and check the resistance after each one. If the resistance is still low after all of the bulbs are out, start checking the sockets and wiring for shorts.
Old 08-14-2023, 09:07 PM
69geeto's Avatar
Well, I found the problem. Wire pinched between the right parking light connector and the frame. Intermittent short took a while to find.
Thanks for all the help and tips.
Stu
The Following User Says Thank You to 69geeto For This Useful Post:
Old 08-14-2023, 09:13 PM
69geeto's Avatar
A quick picture of the wiring .
Stu
Old 08-15-2023, 08:29 AM
69geeto's Avatar
Also should mention that the dash lights and running lights are separated at the light switch. So pulling the switch wires and checking resistance separately, helped narrow things down considerably.
Stu
Old 08-15-2023, 09:30 AM
mzbk2l's Avatar
Thanks for the followup. Was that something that had been apart recently, or did the wire finally just rub through after 40+ years?
Mike
Old 08-15-2023, 11:03 AM
69geeto's Avatar
The car was restored in 92 and not touched since. So 32 years of rubbing that wire to break through.
This one had me stumped for a while. 😆 I'm getting too old to lay on my back looking up through the fender!!
Stu
