OHC-6 TECH Over Head Cam projects, questions and advice.
Old 02-27-2017, 02:41 PM
GTOWAGON's Avatar
GTOWAGON GTOWAGON is offline
Default milling the cam tower
has anyone milled the cam tower for a regrind cam?
I just had an old cam reground from crane and it has a much smaller base circle and machine shop is worried about milling a lot off it would take the lip off of both sides
has anyone done this and did you have any oil leak problems
When you really do something right it's like you didn't do anything at all
1931 Pontiac 5 window coupe OHC6 powered
2015 GMC Yukon SLT
Old 02-27-2017, 09:09 PM
sprintbird sprintbird is offline
Has been done many times for many years. Not any more of a leak problem than without milling.
Old 02-28-2017, 01:11 PM
GTOWAGON's Avatar
I need to take a lot off .215
2015 GMC Yukon SLT
Old 02-28-2017, 02:59 PM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
Are you sure its not half that?
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
Old 02-28-2017, 03:00 PM
That seems like a lot. Approaching 1/4". I thought that it was just a few thou that needed to be milled.
Old 02-28-2017, 04:55 PM
GTOWAGON's Avatar
measurement from face of cover without the gasket is 1.696 and crane says I need 1.380-1.386 the cam is a h320 I already have valve stems .050 longer from the previous cam and can shim the lash adjusters .050 but still have to make up the difference
2015 GMC Yukon SLT
Old 03-01-2017, 02:26 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
That would mean that the cam's base circle (diameter) was reduced .430". Huh???
Old 03-01-2017, 07:41 AM
GTOWAGON's Avatar
That's what it looks like waiting to hear back from crane
2015 GMC Yukon SLT
Old 03-01-2017, 11:01 AM
GTOWAGON's Avatar
reduction is .314-.320
2015 GMC Yukon SLT
