Old 03-04-2017, 05:20 PM
Judge273's Avatar
Judge273 Judge273 is offline
Default Master cylinder rebuilder recommendations
After sending my Master and proportioning valve to Apple Hydraulics. I just got them back with the verdict that they can't do the needed work....
Well, before I give up and go the repop route. Does anyone else have a recommendation?
Anyone have luck on tough pieces before?
Mike/Illinois
Old 03-04-2017, 06:18 PM
68bird400HO's Avatar
What is the problem with the MC. Is the bore pitted? If not, they are pretty easy to rebuild yourself.
Old 03-04-2017, 06:44 PM
Judge273's Avatar
Here is what they said... Master is seized/frozen and only way to get guts out is to drill a hole on the other end, push everything out, then plug the hole, then get all new internal parts, even these that are not in rebuild kit .... bottom line, cost to do master is $420 ($175 above standard cost).
Mike/Illinois
Old 03-04-2017, 06:45 PM
Bentwheelbob's Avatar
White Post in Virginia.
Old 03-04-2017, 07:46 PM
Judge273's Avatar
Not seeing the good endorsement there? Have a good experience?
Mike/Illinois
Old 03-04-2017, 08:05 PM
Yeah, they did a crappy job for me, but thought I would try to steer you off course to a fly by night shop....
Actually, they did a great job for me on my master and prop valve.
Old 03-04-2017, 08:14 PM
njsteve's Avatar
njsteve njsteve is offline
I have used Whitepost on several master cylinders and brake cylinders. Very satisfied and they guarantee their work. If you have a "survivor" part with a finish you don't want altered make sure you tell them so they don't paint it. Usually a one day turnaround. I have sent several to them by FedEx ground on a Monday and had the unit back in my hands by Thursday. Usually runs around $175 to do a master cylinder.
Old 03-04-2017, 08:54 PM
GRNMTGOAT's Avatar
GRNMTGOAT GRNMTGOAT is offline
I had mine rebuilt with a stainless sleeve by Karps,seems to be a nice job.
http://www.karpspb.com
1970 T/A RA3 #'s match.
Old 03-04-2017, 09:08 PM
I did mange to get on severely stuck one apart that was in a junkyard for 30 years. It was a not fun. Hard to believe this one could be that bad unless it also was sitting in a yard for decades.
Old 03-04-2017, 10:41 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
PY member 70RAIII restored three of them for me and they turned out great!!
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 03-04-2017, 10:46 PM
FunctionalShaker FunctionalShaker is offline
Mike, I've gotten a number of them apart that were pretty seized. Just takes a little effort. Squirt a liberal amount of penetrating oil in each orifice and let sit for awhile. The first piston is easy to get out as you can drill a hole in it and thread it, then use a bolt to pull it out, after you remove the retaining ring. You can use a socket extension and a socket that matches the piston head to "bounce" the rear piston free. (note: try this first with the accessible piston as this helps to loosen it. Sometimes the pistons will stick in farther, but they have springs behind them, so there's tension there. A long needle nose pliers helps to grab hold of the second piston's nub. It's just a matter of trial and error. I haven't had one beat me yet.
I've had success with Apple. M.C.s are easy to rebuild so I just had them put the brass sleeve in. That's $115.
Norwood's Avatar
Norwood Norwood is offline
Ya Mike I agree 70RAIII does Great work
Old 03-04-2017, 11:08 PM
Craig, did Bill sleeve them himself, have someone else do it then finish the rebuild, or just put new seals in and refinish?
Old 03-04-2017, 11:52 PM
NEW64OWNER's Avatar
NEW64OWNER NEW64OWNER is offline
Karps
Old 03-05-2017, 01:30 AM
weranc55's Avatar
weranc55 weranc55 is offline
Have you used them yet?
Old 03-05-2017, 05:55 AM
Norwood's Avatar
Bill to the best of my knowledge dosent own a mill or any other method of boring the body. So if he did he sent it out to be done.
Old 03-05-2017, 08:14 AM
Judge273's Avatar
Thanks for the great advice! I'll try whitepost and leave my options away from Bill.
Who, I'm sure is familiar with the car. Funny, I actually saw the correct rebuilt master on the shelf with the correct starter too. Not sure how they disappeared when I needed them along with a lot of other key pieces...
Mike/Illinois
Old 03-05-2017, 11:18 AM
PureSD's Avatar
PureSD PureSD is offline
Also had good luck with White Post. Very knowledgeable guys.
1972 Trans Am Lucerne Blue /white 4spd
1973 Trans Am 455 4spd, White/Black..Junior Gold POCI 2012
1974 Trans Am SD455 4spd. 29k mile unrestored. Buc Red/white
1948 Lincoln Continental Cabriolet V12. Restored.
1951 Willys Jeepster 6 cyl.
1968 Olds Cutlass W31 Ram Rod. Nocturne Blue, 4spd, stripper
1969 Hurst Olds survivor
1970 Challenger RT Convert . 383 4spd. Plum Crazy/white
1971 Datsun 240Z
1978 Datsun 280Z Black Pearl edition
1983 Jeep CJ7 Renegade
2013 Corvette Gran Sport
Old 03-05-2017, 11:57 AM
Whitepost will only do a full rebuild, so you don'the get the option to save some coin and do the easy part yourself.
Old 03-05-2017, 02:19 PM
Norwood's Avatar
Mike isn't trying to save, he just wants the job done right
