Shifter Positioning
I installed a TKO600 in my '65, I have found a Hurst bar that could be adapted to the TKO but need the correct positioning of the bar.
Based on a stock 4-speed Hurst bar in neutral: - what is the height from the tip of the bar to floor sheet metal - what is the distance from the tip to a measuring point on the dash I will adapt the bar/mount to match. Thanks for help! Tone
"Listen to her why-ee-eye-ine......... Listen to her why-ee-eye-ine" 1965 GTO Post Coupe, Burgundy w/Parchment, 467, Crower 60243, Rhoads V-Max, Ported 5C's, JB Roller Rockers, Original '66 Tripower, Dave's Small-body HEI, RA Exh Manifolds, 2.5" Exh X-pipe w/Super Turbo's and SS Splitters, Tremec TKO 600, 3.91 12-Bolt Posi w/bearing retainers, boxed frame, 4X Discs with hydro-boost, EPAS |
OK, how about just from the tip of the shift ball to the dash??
What is a shift bar? I know of shift rods and shifter handles. Never heard of a 'Hurst Bar'.
Jeff |
shifter
WHAT IS A HURST BAR ??????????????
My GUESS (no real knowledge) is a T handle on the top of a Hurst shifter.
I'm pretty sure BAR = HANDLE.
The '64 GTO The '65 Chevelle The '69 Chevy Pickup Project The Brazen Orange 2006 GTO |
The lever - says "Hurst"
Thanks for asking
I didn't have time today. If I can remember, I can get you some measurement tomorrow.
Thanks, Rich
OK , correct names for "Hurst" shifters- according to "Hurst"
Arms= brackets that are bolted to side of trans ,That the RODS, 1st + 2nd. And 3rd + 4th, are mounted in with bushing and spring clip. Handle= the chrome stick with Hurst logo. Then there are T handles and balls Dave |
Dave,
Not for nothin'..... but I'm honestly looking for the measurements. Just turned 74, to correct all my improper and idiosyncratic grammer would take an entire forum....... nevertheless you are correct. So how about it? All in jest...... Tone
Sorry, didn't get up to the shop today. I'll get there tomorrow.
I appreciate it.
Tone, from the front edge of my shifter ball to the very bottom of the dash is 7" From the top of the ball (original ball) to the top of the carpet in front of the passenger seat (center of seat) is 18 1/4 " |
Thanks, Dave!
Our car is a 64 GTO with its original Hurst shifter. Measurements can be seen in the photos. When the handle is further forward that is 1st gear, when the handle is further rearward that is 2nd gear.
Thank you, Rich!
