Old 04-13-2021, 11:47 AM
Ivo Ivo is offline
Default Experience with Fan Controller Dakota Digital Pac 2800BT
Hallo, i want to renew my electrical setup and i have ordered this duble el. Fans with Schroud
https://www.summitracing.com/parts/FLX-298
I also need new fans controll. There are many comments about Derale, Flex a Lite and others
I am interested in your experiences with the Dakota PAC 2800BT
https://www.dakotadigital.com/index....od/prd1207.htm
and which ones you would recommend to me
Thanks Ivo
Old 04-13-2021, 02:04 PM
leeklm's Avatar
leeklm leeklm is offline
I only have experience with controllers from "Auto Cool Guy", which I would suggest checking out if you have not done so already.
Sent from my SM-G965U using Tapatalk
Old 04-13-2021, 04:35 PM
dhutton dhutton is offline
I am not a fan of simple on/off fan controllers because the fans are noisy. PWM controllers give continuously variable fan speed and fans are quieter.
I have used several of these controllers with good results.
http://www.dccontrol.com/constant_te...ontrollers.htm
I will say that sending him email questions is a complete waste of time. He does not answer. He does ship promptly.
Don
