Old 01-15-2008, 10:09 AM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Default fastest car with kre highport heads?
what is the fastest times that have been achieved with KRE highport heads?
with or without shaft rockers.
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046 jet
First ultra street/ultimate street NOS car to get into the 4's!
1.079 4.559 153.23.
3100 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
T2TTFMF!
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 01-15-2008, 10:36 AM
D. Miles's Avatar
D. Miles D. Miles is offline
I would say Jeff Kauffman's digger going low 7's? then The Tin Indian digger (can't remember the owner/driver at this point) going mid/high 7's. My question would be who's the fastest door car N/A with Kauffman HP's? Seem's that everyone who puts them on gain considerable power, even the swaps from 320-330 range Edelbrocks! Doesn't seem to be alot of K-HP's out there yet though. Glad I was able to make a deal with the high bidder on mine, I wasn't about to let them go for that kind of money! Now I'll just go ahead and get them done... Thanks D. Miles
Going TurboCharged!
Old 01-15-2008, 11:56 AM
slowbird's Avatar
slowbird slowbird is offline
I think there are more out there we just have not heard about them. Not everyone is on the boards.
Old 01-15-2008, 02:27 PM
GTOGEORGE's Avatar
Default KRE High Ports
Bran Smuland with his Turbo MR-1 block 97 Top Sportsmen Firebird. He ran some 7.30's-7.50's at Norwalk with the Boost turned down really low just so he could make it down the track. Car has 6.70 potential!
Old 01-15-2008, 06:24 PM
John Bailey (GTOKID)'s Avatar
John Bailey (GTOKID) John Bailey (GTOKID) is offline
Jeff, can you run them in RAM?
Old 01-15-2008, 07:05 PM
punisher#1's Avatar
punisher#1 punisher#1 is offline
my car @ 3100 pounds all motor with a true ten tire and 4.10 gears ran 8.80's @ 150+. with the gas it ran 8.20's with a mild tune the one time i ran it 1/4 mile; and always runs 5.30's in the eighth with a best of 5.23 @ 138 on one kit.
'78 Ford Fairmont 526ci pontiac; true 10.5 tires and stock suspension.
5.14 @140.5 w/nos; 8.86@151 all motor.8.17@172 1/4 mile w/nos
Old 01-15-2008, 07:07 PM
greggutknecht greggutknecht is offline
Had my Highported 540 in a buddies stock suspension Monte and went 8.68@ 160 on the gas.Greg
Old 01-15-2008, 07:38 PM
aaronman aaronman is offline
Brad Smuland's tubo High Port 505 Bird is capable of high 6's. He has been a frantic 4 contender for the past couple years running low 7's. My High Port headed 535 in a 3200 lb Bird will run in the high 8's this year w/ some changes to the converter and gearing. No power adders.
Old 01-15-2008, 08:40 PM
Jim Zeek's Avatar
Jim Zeek Jim Zeek is offline
Aaron, you and Brad coming to Virginia this year?
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial
http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1
Old 01-15-2008, 08:44 PM
Mo's Avatar
Mo Mo is offline
The fastest I've seen Brad S run on NO2 was a 7.58 at Norwalk 06'. Scott Rex ran the same on motor.
His turbo deal has alot of potential.
Systems under stress fail catastrophically
Old 01-15-2008, 11:55 PM
Brad is planning to make the trip. I will not I plan to be at Norwalk this year.
Old 01-16-2008, 11:18 PM
Flyin79bird's Avatar
Flyin79bird Flyin79bird is offline
Agreed, Smuland seems to have the quickest car w HP's...I should be at Virginia w my new car and motor...just waiting for the car to come back from the body shop so I can put it back together...Kaufmann said car should be high 7's NA and its also setup for a 300 shot... 540 HP's w 2 1050's in a 2700lb 68 Firebird...all on a 33x10.5W...I hope it hooks!
Old 01-20-2008, 04:17 PM
GTOGEORGE's Avatar
Flyin79bird,
High 7's N/A at 2700 lbs. that's around 400 lbs. heavier then Mr. Rex.............SWEET!
I ran 8.24 with only 7 lbs. of Boost at 2,900 lbs., plan on cranking it up to 20 lbs. this year now that I finally have it Certed to 7.50.
NHRA.................................what a pain in the Butt they are.
Old 02-01-2008, 01:38 PM
STALLION's Avatar
STALLION STALLION is offline
Send a message via Yahoo to STALLION
Wink Fastest highports.
Michael Campolucci. 96 Grandprix N/A. 8:28 @165mph,St. Thomas, Ontario,Oct./07. -- 8:32 @ 161mph. /07 Norwalk @ 3000ft. humidity,or something like that. Hopefully be alittle faster in /08!
