high ratio shaft rocker?
Does anyone know of a company that can make custom shaft rocker? Trying to see what can be done about get some high ratio rocker something like 1.9 to maybe a 2:1 ratio. So far no one wants to go beyond 1.8.
I have a set of Jesel 1.9 shafts. They are made to fit the Tigers. Jesel will make anything your wallet will allow.
I've got some 1.8 stud mounted Crowers that fit Pontiacs.
Why would you want more then a 1.9??? I think with a 60mm cam and a 1.9 you can get close to 1.25" lift.
