Closed Thread
Old 12-16-2019, 09:17 PM
Scott Roberts Scott Roberts is offline
Originally Posted by LiL Jack View Post
That’s because you don’t make any power to hurt anything!
Lol..truth.. there are stock blocks taking more than george has...
  #42
Old 12-16-2019, 09:30 PM
How much HP does it take to break a block?
How much for the AP blocks that broke?
Danny Estep ??
Curt Geise ??
GTO on PY ??
TimeWarp ??
Others ??
  #43
Old 12-16-2019, 09:42 PM
GTOGEORGE's Avatar
My engine makes more hp then 90% of the Pontiac out there.....I’m happy!
GTO George
  #44
Old 12-16-2019, 10:24 PM
PAUL K's Avatar
PAUL K PAUL K is offline
GTO George
Being happy is what it's all about!
Go fast, see Elvis!
  #45
Old 12-16-2019, 10:30 PM
GTOGEORGE's Avatar
You know unless your name is Brittany Force there’s always someone quicker! LOL!
GTO George
  #46
Old 12-16-2019, 10:47 PM
Mark G Mark G is offline
Danny Estep ??
Curt Geise ??
GTO on PY ??
TimeWarp ??
Others ??
You forgot Goatracer I will think of a few more ….
  #47
Old 12-16-2019, 10:55 PM
PAUL K's Avatar
GTO George
Always
Go fast, see Elvis!
  #48
Old 12-16-2019, 11:18 PM
mgarblik mgarblik is offline
Danny Estep ??
Curt Geise ??
GTO on PY ??
TimeWarp ??
Others ??
Our on track experience:
3 Stock block Pontiac 455's 1971-1973 vintage
5 billet straight caps. 1.5-2 seasons for each block @ 1100-1300 HP All three blocks broke in the same place up through the #2 main bearing oil feed from the cam bore to the main housing bore.
Indian Adventure Iron: Unlimited runs @ 1300-1500 HP (hundreds of passes and bad tune-ups) No block issues
IAII Iron block: Probably close to 3000 HP Multiple years of running on 90% nitro. Some pretty bad tune-ups, melting pistons through the wrist pins, turning Crower billet crankshafts to liquid, entire car burned to the ground. No Block Failures
IA II solid aluminum block: 3 seasons at 3000 HP 5-6 runs at 3200-3400 HP. 40+ lbs. Boost, 90% nitro, 9000 RPM's. No crank support or harmonic balancer. No block failures. In fact the block will not require line honing this off season. Better tune-ups take massive load off the block. IA II blocks are tough in iron or aluminum
  #49
Old 12-16-2019, 11:51 PM
Go buy lotto ticket...
  #50
Old 12-17-2019, 12:58 AM
Stan Weiss's Avatar
Some of really comes down to tune up.
Marty Palbykin @ 2950 went 6.95 @ 195 MPH using a PMD iron block and heads.
Stan
Pontiac Pump Gas List
  #51
Old 12-17-2019, 01:10 AM
GTOGEORGE's Avatar
Stan
He used a factory block because he HAD to, I’m pretty sure a lot of time and money went into his block. No one likes to play Russian Roulette! LOL!
GTO George
  #52
Old 12-17-2019, 10:19 AM
Tom Vaught's Avatar
Boost Engineer
GTO George
Sorry, I have to respond on this one.
Dick Duclow's IA-1 block was out there at the time.
Rodney Butler chose to run one of those blocks as a 440 cid engine and did for years.
Marty could have bought a Duclow Block if he wanted to.
He chose to use the 1967 400 Block that came from Bill Klausing and put splayed caps on the block. It lasted 3 years and also eventually cracked in the same location as the blocks mentioned by Mike Garblik.
So what was posted was not true and the truth needed to be told..
I will only post here if the post is a bold faced lie.
Tom V.
  #53
Old 12-17-2019, 10:26 AM
opeliac opeliac is offline
Didnt Marty run a filled block?
  #54
Old 12-17-2019, 11:16 AM
GTOGEORGE's Avatar
Anyone know what year the IA block came out? I bought one, I’m trying to remember what year it was that I got it........2004 or 5. Jeff had one in his shop but at that time they were almost impossible to find at that time.
GTO George
  #55
Old 12-17-2019, 11:37 AM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
Larry Quinn broke his block also
Illinois Outlaw Gassers
6.27@107
9.97@131
  #56
Old 12-17-2019, 11:55 AM
Tom V.
Then we will be seeing a lot of you..
  #57
Tom Vaught's Avatar
Boost Engineer
Post by Scott Misue in 1999
http://forums.maxperformanceinc.com/...12#post1712412
"Gach is not an easy man to impress. However, Marty's accomplishments with turbos has definitely caught his attention. Lou seems to be a bit miffed by the fact that Marty wasn't given, sold, or stolen, a block to test. I think Lou's ire may also stem from the fact that Marty isn't a vendor of this block and, as such, wouldn't conceal his combo, reults, or the components employed in its testing."
So Scott Misus way back in 1999 was complaining about Marty P not having access to an Indian Adventures block, not that he could not afford to buy one.
Tom V.
So the reply by George was BS.
  #58
Old 12-17-2019, 11:57 AM
Tom Vaught's Avatar
Boost Engineer
At least on this one subject but I have posted to correct info and the timeline so I am out of here again.
Tom V.
  #59
Old 12-17-2019, 12:06 PM
GTOGEORGE's Avatar
WOW. I think someone is PMSing! LOL!
GTO George
  #60
Old 12-17-2019, 12:25 PM
GTOGEORGE's Avatar
Cool I opened the link and read all 3 pages......damn that was some good reading! Gacht was a jerk back then also! LOL! At least I now when the IA block came out ( I was kinda guessing). I was rethinking and maybe I got mine in 2004, darn now I have to go looking for my invoice from KRE!
GTO George
Closed Thread
