Old 06-30-2012, 12:37 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
I always thought you would just put 65-66 style 389 pushrods and stock rockers on a 62 or 63 389 without issues. If early engine is rebuilt with the upgrade of the normal 60 psi M54DS pump/screen kit it is more pressure than stock which would supply plenty of oil but too much? If it drains properly its hard see it being too much as long as the Oring valves seals and oil shields are installed properly. Seems the cooling effect of the oil on the springs and no wear on the pivot ball rockers spot would be great for a low lasting low rpm cruiser. main benefit would be instant oiling on dry startups after sitting for many months during the long Wisconsin winters. IMO..
Are the rockers the same spec on a 62-63 as later 389 but only missing the oil hole?
63 Catalina coupe 455 budget drag car 11's 1/4 , 7.4 1/8th
66 Star Chief Executive 57k mile
69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2007 Hummer H3 3.7 liter turd
2019 Chevy Spark petrol car 38 mpg
Old 06-30-2012, 04:08 PM
tom s tom s is online now
Larry,geometry is the same on 63 rockers if they have oil holes or not.The 716 heads had pushrod oiling and all other(except SDs) had stud oiling.Tom
Old 06-30-2012, 05:00 PM
Thanks Tom, I thought so. I also meant "long lasting, low RPM cruising " not low...sic
