Old 05-02-2025, 01:12 PM
Quentin Quentin is offline
Default Exhaust Manifold bolts for Firebird 1978
Greetings!
Sorry to bother you but I failed to find the response so far, so I'm reaching to you.
I buy not long ago a Pontiac Firebird Trans AM of 1978 (the engine is a Pontiac 400) I had to do the head gasket and so replace the exhaust manifold gasket of course. I also replace the bolts that was there by exactly the same:
- Diameter: 3/8
Thread: UNC
Quantity: 12
https://www.transfixations.fr/fr/vis...tre-3_8_9525mm
- Diameter: 3/8
Thread: UNC
Quantity: 2
But I think that those bolts are not the corrects one, they seen to be a bit short and holding only on a few threads...
I live in France so I cannot go to the store to test what would fit the best, i would like some help to get the size right, if anyone as the info
Thanks in advance!
Old 05-02-2025, 01:42 PM
starlightblack's Avatar
starlightblack starlightblack is offline
Those bolts in the links you provided are NOT CORRECT.
As well, AMES PERFORMANCE does NOT have the right kit for a 1978 stock exhaust manifold, even though their catalog lists it. I know this from experience, having ordered their kit.
The 1978 does NOT have a combination of long and short bolts holding the manifolds to the engine. They are all one length.
You are better off ordering this:
https://www.ebay.ca/itm/312906392252
"Spend all your time and money on that Pontiac GTO pile" - The Go-Gos, 1981
Old 05-02-2025, 02:58 PM
My 78 bolts were also hollow.
2004 GTO Pulse Red stock motor computer tune 13.43@103.4-sold
Old 05-02-2025, 05:32 PM
Hello thx for the replies!
Yes I read somewhere during my recherche that the bolts might be hollow to handle dilatation. On the link shared by @starlightblack I'm not sure if they are hollow or not. But I guess I will for for them (except if someone has a contraindication)
Old 05-03-2025, 10:29 AM
And hollow ones are easier to break off when rust seized!
Old 05-05-2025, 12:51 PM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
^^^ But also easier to drill through, haha.
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
