Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 01-10-2023, 05:34 AM
chuckies76ta's Avatar
Default Rimac Spring Tester
This is an older model. It goes to only 250 lbs.
In nice shape. I tested it with my test spring and it was right on the money. $200 plus shipping. Thanks.
ID:	604862   Click image for larger version
Old 01-11-2023, 11:23 AM
Reduced $150 Thanks Anybody know if this can be upgraded to 500 or 1000 psi unit?
Old 01-11-2023, 03:05 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Rimac sells the different springs and dials for someone wanting it to go higher. not that expensive.
Skip Fix
The Following 2 Users Say Thank You to Skip Fix For This Useful Post:
Old 01-11-2023, 04:21 PM
cdnroundport cdnroundport is offline
PM sent
Old 01-11-2023, 08:27 PM
Lee's Avatar
Lee Lee is offline
If it isn't sold, I'll take it.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 01-12-2023, 07:44 AM
Going to put this on hold till I find out a bit more info on it. Got an email sent to Rimac . Thanks Lee for interest. Have a couple members already interested. will keep posted. Thanks
The Following User Says Thank You to chuckies76ta For This Useful Post:
