1/8" steel mid plate.
Who makes one for our engine ?
It the time, I’m not sure if they made one for a BOP so I made my own at work out of 1/8” steel.
GTO George |
3/16 is the way to go. All the thin ones end up bent
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
Use chrome-moly plate.
Stronger plus lighter. (when using the thinner 1/8")
You must have used Chinese steel! LOL!
GTO George |
You can Use a Chevy plate, just make it fit installed backwards for starter. If using factory block, just weld a couple of tabs up top where trans bolts to block.
Dave Polichena |
Who sells them ?
My converter was not made with a mid plate in mind so I can only put it mack so far. If its made out of high grade steel that would be great. I use Alston stuff. High quality. |
http://allpontiac.com/midmotor_125.html
https://butlerperformance.com/i-2445...tegory:1234736 Works great!
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159 2009 G8 GT |
Called Alston and they do make a 10 gauge mid plate more designed for stock frames. A little wider side to side. But its like 180$ vs the 60 bucks for the .100 thick plate.
BTW, nice work Erick. You do that yourself ? |
I make my own.
Called Frank, guy is great. What I have to do is put the converter up to the crank with flex plate on and set it back the 3/16 with washers. And make sure it is centered exactly. Some converters are different/tapered. Its all about being centered , not the tangs for the pump.
Also he makes a front plate for my frame too that has nothing to do with timing cover so its pretty easy. Even if I have to go with a .100 in the back this front plate is the way to go. Off with the elephant ears. They turned out really nice but put pressure on the head. One thing with iron heads but going to aluminum. |
How long does it take you ? I thought about it but if I can buy one for 60$ or 90$ that's more than worth the time and hassle.
Alston mid plate, All Pontiac front plate.
(Gen 2 Firebird sub frame)
Nice work BTW. |
The plate will need fitted around your headers and frame width more than likely. I have a few patterns I can use after I put the engine where it belongs and cut one out in a few hours. You have to make sure your snout on the converter is in the crank to. I run ati converters and can change the pilot out for a longer one. They sell correct shins for the ears to
The Following User Says Thank You to chiefbigb For This Useful Post: | ||
After breaking a trans case I'm upgrading from a 3/16 steel to a 1/4 7075 aluminum.
Blank Rear Motor Plate - Chevrolet dowel pin holes Product Code: 38100 24" x 24" with crank and vent holes, Chevrolet dowel pin holes. 1/4" thick, 7075 aluminum alloy. Allows profile to be cut to match existing or special plates. Manufacturer: Mark Williams Enterprises, Inc.
2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
My son Nick does all of my fab work, our converter was ordered for use with it. Check out the whole build in the Boost forum. "Boosted Bandit build thread"
Thread Tools | |
Display Modes | |
