Old 05-03-2020, 07:35 PM
KGTO's Avatar
KGTO KGTO is offline
Default Line lock plumbing question
In the past I've always plugged one port on the 4 way distribution block, run a new line to the solenoid, then tee to the front brakes.
Why can't I come off the MC, go in the solenoid and out to the 4 way block?
I will be adding a proportioning valve too, not sure if that makes a difference.
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
Old 05-03-2020, 07:55 PM
leeklm's Avatar
leeklm leeklm is offline
In my 68, I was not getting enough brake to my rear discs. I ultimately eliminated the factory distribution block and connected my front line directly from MC to the line lock, then out to a T for the front brakes.
Rear line connected directly to the Wilwood MC and back to the rear brakes.
Since you plan to use an adjustable proportion valve, no reason you could not completely eliminate the factory proportion block.
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
Old 05-04-2020, 10:11 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
"Why can't I come off the MC, go in the solenoid and out to the 4 way block?"
My cars are that way. Seem to work fine.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 05-04-2020, 10:47 AM
KGTO's Avatar
That's what I'll do, thanks
1964 421 GP-Sold
Old 05-04-2020, 11:13 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I use mine as a T for the front brakes(one in from MC and two out of line lock) and a straight line in the rear with an adjustable prop valve in it.
Skip Fix
