Old 05-26-2020, 05:53 PM
Larry Navarro's Avatar
I'm having a SS exhaust being fabricated for my '79. The "craftsman" is building it from mandrel bend tubing sections, 3" front & 2.5" rear to splitters. It's expensive but it will be worth it when the car rolls over the "undercarriage cam" at B-J.
I see so many nice cars for sale, then see at a half-assed exhaust system underneath. It says alot about how the rest of the car was done.
Old 05-26-2020, 06:28 PM
Gach's Avatar
Gach Gach is offline
My experience with Exhaust systems, if it helps. I ran 3” Dr Gas crossover. Exact same system as ( Pipes ) which was originally Dr Gas... with mufflers. 2” headers 3-1/2” collectors. So collector had to be reduce to 3”. Which I think is one of the killers...just guessing
Now I run 4” Merge collector, with 4” Bola stainless steel mufflers, with turn downs in front of rear axle. Car pick up .3 tenths over crossover system. Absolutely no difference with open headers in ET.
I pop off the turn downs and put cones in to meet the 90 decibel level for street
It as quiet as Pipes system.
Its A body car so plenty of room to run 4” pipe. Straight back from the headers. No fumes what so ever get in the car from the exhaust. Of cruse it only applies if you have the room.
Heres a video of what it sounds like with 4” and cones
https://youtu.be/I2gvpy0fNN8
Old 05-26-2020, 06:33 PM
lust4speed's Avatar
Originally Posted by 64speed View Post
...The muffler is the dynomax 17229... Anybody got any feedback on these mufflers?
I prefer the longer case, but the determining factor will be what the Pypes system was designed for in regards to case length and inlet/outlet positions.
I've always had good luck with Dynomax mufflers. On a friends car he went from cheapy turbo mufflers to Magnaflows to finally Dynomax mufflers to solve a nasty drone. First two were terrible and the Dynomax worked.
Back 18 years ago there were few options when going with a mandrel bent 3" system, I ordered and installed a kit from Torque Tech. Not a bad setup and the exhaust is still going strong today (unfortunately Torque Tech is not). Muffler of choice back then was the Flowmaster Delta Flow 50 Series. Would opt for the Dynomax today, but I have to say that the Flowmaster 50's don't have a drone and have a good sound.
Anyway, there's really plenty of room under the A-body chassis and over the axle. Here's a shot showing the pipes over the just-installed Dana 60 a few months ago.
Mick Batson
Old 05-26-2020, 08:31 PM
I am going to run full pipes. The muffler is the dynomax 17229. Anybody got any feedback on these mufflers?
Yes. Those are the shorter 14" versions. I actually prefer the longer 18" version but I do have the 14" installed on my sons mustang (18's don't fit that car). It's a complete 2 1/2" mandrel bent system with tailpipes, and a BBK "X". It's very mellow, no drone, and can easily carry on a conversation or listen to the radio. It makes a little bark at full throttle but cruising is very nice.
I run the 18" Dynomax Ultraflow version on a complete 3" system on my chevelle with a Dr. Gas X, with 3" tailpipes. I originally had Flowmaster Super 40's on the car which are 14" long. It was loud all around and droned pretty heavily at 2,000 rpm. The switch to the 18" Dynomax Ultraflows was a huge leap in the right direction. No more drone at 2,000 rpm, and idle and light throttle cruise are now fairly tame. It's noticeable but not overly loud. Full throttle it wakes up and makes some noise. The biggest improvement was the low speed and light throttle cruising, it's so much more enjoyable. Wife is actually happy to ride in the car now and I've even found myself driving it more lately.
https://youtu.be/XqEydRRRwqE
Old 05-26-2020, 09:13 PM
64speed's Avatar
64speed 64speed is offline
What’s the part number for the 3 inch inlet/outlet 18 inch case ultra flow dynomax. The only ones I can find are 20 inches
ta man ta man is offline
I can give a Tinkers damn about loosing 25-30 HP on a street car!I just want to be able to drive it a highway speed and listen to my radio!80 plus dec on a street car SUCKS!JMHO,Tom
My car is pretty quiet inside with full 3 inch exhaust..I have a video somewhere on this site.
Old 05-26-2020, 09:16 PM
What’s the part number for the 3 inch inlet/outlet 18 inch case dynomax
17547
And my bad, they are 20" not 18. They are offset/offset 3" in and out. The Pypes exhaust system is bent for offset/offset if you are wondering which is a very typical setup.
Old 05-27-2020, 04:39 PM
70GS455 70GS455 is offline
17547
I'm not sure about the Ultraflow, but on their Super Turbo, the 3" necks down to 2.5" internally on the smaller (4.75 x 9.5) case. The ST have 2 case sizes and the larger 5.5 x 11 case maintains 3" throughout
Sent from my SM-T817V using Tapatalk
Old 05-27-2020, 04:46 PM
The Ultraflow maintains 3" throughout. I should have taken some pictures but I didn't. Even though it's an offset design, the pipe shoots straight through.
Old 05-27-2020, 05:36 PM
77 TRASHCAN's Avatar
77 TRASHCAN 77 TRASHCAN is online now
I like this thread!!! Thanks ALL!!!
It's like the old saying, A crazy amount of horsepower is just enough!
4" collectors and 4 " exhaust pipes, I'd like to see some pictures of those!!!
Back in the 80's my buddy fabbed up an exhaust system on his 66 C-10 pickup. Ran 2.5" pipes off the headers. Ran the pipes outside the frame, all the way to the bumper.
The best sounding and flowing muffler back then were the Super Turbo mufflers. Those mufflers were TOO loud for his liking (Tom S. reminded me of this...LOL) So he goes and buys 2 more of the same mufflers (all pipes and mufflers were 2.5" 2.5" was about the biggest pipe size hot rodders used back then. 3" pipes were just beginning to be used).
The 4 muffler deal worked great (2 mufflers on each side, end to end), sounded good too!!! The 406 small block/Muncie M20/3.42 gear pickup was a bad customer on the street!!!
Shut it off
Shut it off
Old 05-27-2020, 05:57 PM
Gach's Avatar
Unfortunately I don’t have one with full exhaust system under car, but this give some kind idea.
Old 05-27-2020, 06:10 PM
64speed's Avatar
I just don’t understand why the Pypes people themselves say it would hurt performance under 600 HP
Old 05-27-2020, 06:45 PM
IMO, the best sounding mufflers of all time were the Smithy's "Steel Pack" mufflers and they
had a very pleasing sound going down the road and worked well under power too.
You remember those mufflers Tom S? apparently speedway still sells a glasspak version today.
"Smithys Glass Pack Mufflers are designed for great performance with excellent tone. Double end cap construction and 3-1/2" hammertone finished cases assure the original Smithy look.
Worlds oldest performance muffler
Perfect for that resto-rod or 1950s custom
3-1/2" diameter seamed steel case
2" I.D. inlet and outlet"
Old 05-27-2020, 07:30 PM
Hang tight, I'll dig out some pics of a 4" Mufflex system I installed on one of our 4th gen Camaros a few years back. It was a work of art.
Old 05-29-2020, 09:35 PM
Old Man Taylor's Avatar
I had the Super Turbos (Dynomax) that necked down inside on mine until they came out with a stainless steel muffler that was 3" all the way through. Unfortunately I think they discontinued it. It was P/N 17774.
Old 05-30-2020, 01:21 PM
1968GTO421's Avatar
I used to run Smithys back in the '60's on a 394 Olds with Isky E-2, great sound, no drone. Some of the older speed shops/auto parts stores back then had some of the steel packs left over in their back room/storage areas. Those did sound great. Smithys kind of died out as Turbo mufflers became the performance muffler, although in the late '60's street Hemi mufflers also became an "in" performance muffler.
Thanks Tom for the Smithy reminder, sometimes I see them mentioned on the HAMB.
GTOAA--https://www.gtoaa.org/
Old 05-30-2020, 01:30 PM
Most probably never heard of Smithys but they are still out there I believe.
Think they still offer Glasspack mufflers today. Others would recognize the name but not the difference between the steel packs and glass packs in the old days and the sound difference between the two.
Yep, people started reading about Corvair Turbo mufflers, etc.
  #38
Old 05-30-2020, 01:34 PM
flat-bill flat-bill is offline
Default mufflers
https://pertronixbrands.com/products...2-inlet-outlet
Also available from Speedway Motors.
Billk
  #39
Old 05-30-2020, 01:37 PM
1968GTO421's Avatar
You're are certainly right, Smithys are now made by Patriot exhaust who also owns Dougs headers. Patriot is owned by---Pertronix
  #40
Old 05-30-2020, 02:09 PM
I've seen Smitty mufflers on Speedway advertisements in magazines...
Shut it off
Shut it off
