Old 03-21-2009, 12:04 PM
Z Code 400 Z Code 400 is offline
I cannot get my car toeven get up to 185°F with the Lincoln, 7 blade fan, even in 100°+F ambient temperatures, but it willrun 220° all day long (even when it is 39°F outside) with Severe Duty clutch and 7 Blade Fan shwon in my previous post above.
That's why I switched. It's just sitting on the bench now. I figure we will try it on my 11 year old son's 331 CID Camaro project and see if that engine likes it any better. It might work on that car, as it has the smaller, A/C style pulleys...Robert
  #42
Old 04-04-2009, 11:45 PM
59safaricat 59safaricat is offline
Z-Code,
Does that Lincoln fan have a part #? I asked my buddy who is a Ford fanatic and has a wall full of books packed with part#'s and interchange #'s. He couldn't find a factory flex fan for a 68 Lincoln. All 68 Lincoln fans required a clutch, according to his vast info.
  #43
Old 11-04-2009, 04:34 PM
Safari,
It's a rather obscure piece. Your friend is correct that all Lincolns were originally equipped with clutch fans during that era. However, there is an explanation. A friend of mine worked for a local Ford dealer for many years. When I was looking for a big 7 blade flex fan, he suggested the one that Ford put on Lincolns.
Apparently, there was a TSB for an overheating condition that provided for a 13 fpi radiator an 7 blade flex fan. The part number, C8SE-8546-B, later crossed to the same 18" fan that was used on the 428 CJ cars, which was available under part number D0TA-C.
Beware of the 19" 7 blade flex fan used on the Boss 429's under part number D0OE-A. That will not fit in the factory fan shroud of a second generation Firebird.
Hope this helps...Robert
  #44
Old 11-04-2009, 07:56 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Robert, Could you post a picture of your Lincoln flex fan?
  #45
Old 11-04-2009, 08:08 PM
JSchmitz,
No problem. It is, of course, almost identical in configuration to the 7 blade flex fan found on Pontiac Grand Safari Wagons. The difference is, the 'Lincoln' fan is much, mush more quiet at all rpm levels and moves more air...Robert
P.S. The 'Lincoln' fan is pictured below...
Name:	7 Blade Lincoln Fan.jpg
  #46
Old 11-06-2009, 07:01 PM
blue goats's Avatar
blue goats blue goats is offline
'Use the fan clutch or the flex fan, but don't use a fixed stock fan." Mick aka lust for speed
Why? I have a stock for something 6 blade GM ? fan. My 69 GTO never goes over 170 in the worst traffic . It is mostly stock 4sp ,ac (not installed at this time),4 row PY rad, and I run this car hard most of the time.
  #47
Old 11-06-2009, 07:19 PM
mchell's Avatar
mchell mchell is offline
I just went back to my stock flex fan from a 5 blade clutch fan (heavy duty clutch).... the flex fan reduced my temps by 20 degree's....I always thought I was running a tad hot with the clutch fan setup...
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
  #48
Old 11-06-2009, 08:27 PM
theYman's Avatar
theYman theYman is offline
I swapped out my clutch fan for a flex fan last summer. My car runs cooler even in stopped traffic at 103 degrees. I'll never go back to a clutch.
The thick CLOUD of tire smoke ,the SMELL of burning rubber,and the CHEER of the crowd ....PRICELESS.
$90.00 fine for an awesome burn-out,worth every penny...
http://www.youtube.com/watch?v=iI7beXh7xW8
  #49
Old 11-08-2009, 04:26 PM
7 Blade Lincoln Flex Fan on-duty in my 1975 Formula. Note the Ford pattern visible between the factory Pontiac spacer. This is the spacer that came from the factory Pontiac 'Power-Flex' 5 blade fan. The difference in airflow is unreal and the Lincoln fan is the most quiet of any solid, flex or clutch-type fan tested...Robert
P.S. Pontiac used a 7 blade felx fan on Safari Wagons as part of the heavy duty cooling pacakge...Robert
Name:	7 Blade Lincoln Flex Fan.jpg
  #50
Old 11-08-2009, 06:29 PM
Garage Goat Garage Goat is offline
I'm not saying flex fans are junk. I ran a plastic one for years with good success. I've also ran several kinds of aftermarket, and factory, metal flex fans. None of them held a candle to a good clutch.
I tottally agree with you. From experience a good clutch fan will out perform a flex fan any day of the week!!
  #51
Old 11-08-2009, 09:34 PM
1qikta's Avatar
1qikta 1qikta is offline
I ran my stock 6 blade fan with a HD clutch (AC Req) for a long time until I was looking for more power. I then picked up a factory mopar lightweight 5 blade fan and went down to a standard (no ac) clutch.
The chassis dyno gave me an additional 8 rwhp...
Nothing is impossible if you break it down into possibilities. It's all a matter of "Want to".
  #52
Old 11-09-2009, 01:37 AM
mchell's Avatar
do you drive your rig on the street much??.....any comparison of a stock flex fan vs. clutch fan on the dyno??....curious what i might be losing (if any) going back to the flex fan...I did not see any ET difference going from flex to clutch fan when I initially changed.
I drive mine on the street often so a 20 degree drop was fairly dramatic....
  #53
Old 11-09-2009, 08:28 AM
1qikta's Avatar
I drive to local cruise ins. Never really had a temp issue though.But,I only tested the one scenarion above.
You are not going to see an ET difference..only a slight mph increase with the additional power.Et for me is all about 60' especially with a heavy car.
http://cgi.ebay.com/ebaymotors/MOPAR...Q5fCarQ5fParts
  #54
Old 11-09-2009, 10:16 AM
On our 427 Ford Tunnel Port Drag Car, we ran flex fan, fan clutch and no fan and ran the same E.T., same MPH and same 60' every time and that was on an honest 550 HP car.
Since that time, we chase the fan that gave us the best tempreature management...Robert
  #55
Old 11-09-2009, 12:11 PM
mchell's Avatar
same for me...all about the 60' when you are trying to launch a 4000 lb rig...just wondering what your experience was....
did I talk to you at the BOP race in Gainsville???...dark blue T/A ?
  #56
Old 11-09-2009, 12:23 PM
1qikta's Avatar
Yep that was me..
I think you were originally from Minnesota? Maybe I got it wrong I talked to a bunch of guys from Fl.
  #57
Old 11-09-2009, 12:24 PM
71 T/A 71 T/A is offline
I've tried both flex fans and clutch fans and the clutch works better. I'm using a non thermal fan clutch on both my 69 GTO and 72 Formula and they out perform thermal clutches by running 10-20 degrees cooler.
  #58
Old 11-09-2009, 03:09 PM
mchell's Avatar
Yep that was me..
yeah.....that was me...you going again this year??....I am going to attend..
  #59
Old 11-09-2009, 04:26 PM
You might be onto something there....I have always used the thermal clutches and I understand they cause the engine to run hotter. We used to sieze the non-thermal ones up and then jump the belts on our oval track cars, so we reckoned the bigger, severe-duty thermal clutches were better. Truth is, the cars ran cooler with a flex fan and our lap times never changed so we stuck with it....Robert
  #60
Old 11-09-2009, 05:30 PM
I know someone who runs 11.70s with a 73 Trans Am who has used a nonthermal fan clutch for 7 years with no problems. He said I'd run cooler with the nonthermal and he's right. Plus, they're only $20-$30.
