Old 05-23-2020, 05:08 PM
RedDirtRoad RedDirtRoad is offline
Who’s compound are yah using ? Hopefully not one that’s full of fillers...
Using Mothers profession line 81232 for removing sanding scratches and Mothers 83432 and Rupes Zepnir Gloss on Rupes foam pad
I dont believe these products have fillers since the say they are silicone free
  #122
Old 05-23-2020, 05:29 PM
MUSLCAH MUSLCAH is offline
You’ll find out if it’s loaded with fillers.....when you bring it back inside undah those lights in a week or so.....and it looks like you nevah buffed it.
  #123
Old 09-13-2020, 01:09 PM
I been making slow and steady progress getting the car back together.
I installed my newly refurbished dash and had the gauges done by Instruments Specialties.
I installed all the under dash ducts, heater and evap. box, factory AC and got my steering wheel back from being refinished as well
ID:	549420   Click image for larger version
ID:	549421   Click image for larger version
ID:	549422   Click image for larger version
ID:	549428   Click image for larger version
  #124
Old 09-13-2020, 01:41 PM
tempest1964's Avatar
That’s looking very nice. Well done!
  #125
Old 09-13-2020, 02:26 PM
Mike Davis's Avatar
Looking good,
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
  #126
Old 09-13-2020, 03:16 PM
Rebuilt the shifter and re chromed the handle and bezel
  #127
Old 09-13-2020, 03:24 PM
I had all my stainless trim refinished and polished and installed. New tail lights, gaskets, wiring harness and trunk light installed.
All circuits are operating with no bad grounds or blown fuses.
  #128
Old 09-13-2020, 03:29 PM
I sent my car back to my body guy to align the doors, fenders, hood and deck lid since these parts were painted off the car and were re hung my my painter temporarily
I have no patience for that type of work.
Its really coming together now and seeing progress
  #129
Old 09-13-2020, 05:16 PM
Little tip for yah....unless your guy already has some.. this tape is put down first ...before you go installing those lower stainless moldings and some window moldings.... to prevent paint damage.
  #130
Old 09-13-2020, 05:23 PM
ZeGermanHam's Avatar
Looking fantastic, Dominic! There's light at the end of the tunnel.
1998 BMW 328is (track rat)
  #131
Old 09-13-2020, 05:47 PM
Attachment 549490
Interesting, Thanks for the tip .
Why do you prefer that tape over 3m masking tape ?
Does that tape have a name or product number?
  #132
Old 09-13-2020, 08:30 PM
That tape is similar to 3M stone guard patches ...found on newer vehicles ,in areas of road rash from sand and rocks. But this tape here has very low amounts of adhesive....and can be applied to fresh cured paint and easily removed. It is tough and fairly thick. Blows masking tape away for the intended use. Just google the info on the pic...and you should find it for sale...somewhere. You’ll use it...once you booger up a panel...trying to slide a molding onto its clips..
  #133
Old 09-13-2020, 08:31 PM
What plant was your car built at ?
  #134
Old 09-13-2020, 08:37 PM
Thanks for the tape info
I was on Marcy website and they have a lot of products
I believe this car was built at the Pontiac plant
  #135
Old 09-13-2020, 08:58 PM
My car was built at the Pontiac plant also. Here is a pic of my un restored firewall. I was told that the Pontiac plant ...extended the body color onto the upper part of the firewall...as shown in my pic. Just putting that out there .Click image for larger version
  #136
Old 09-13-2020, 09:06 PM
Yep you are correct
My painter wanted to duplicate that too but I wanted a more finished look even though that’s not original
  #137
Old 09-14-2020, 09:47 AM
ZnbOlds455's Avatar
ZnbOlds455 ZnbOlds455 is offline
Red, I see your front/rear wiring appears to be laying in a track. Did you just line the factory path with tape or did you use the OEM front-to-rear harness?
  #138
Old 09-14-2020, 10:08 AM
I am using the OEM ribbon going from front to back and using 4 inch tape just to hold it down inside the floor channel that’s formed in the floor pans.
  #139
Old 09-14-2020, 10:15 AM
Yep you are correct
I'm with you on this one. My car was also built at the Pontiac plant, but I prefer the cleaner look.
Sent from my Pixel 4a using Tapatalk
  #140
Old 09-14-2020, 10:44 AM
Yep Karl you know the deal. With The exception of us Pontiac purists on this site, most don’t know the overspray on the firewall is the correct way.
I just don’t want to have to explain that to others that look at my car thinking the overspray on the firewall was a sub par restoration.
