Tricks for refurbishing door latches & hinges?
I'm getting ready to hang the doors back on the '66, but first I'd like to clean up the door latch mechanisms and the hinges. The hinges are cast aluminum, and have thick paint on them. The latches are just generally crusty looking. All were working fine without issue before disassembly, so I was planning to reuse them.
Media blasting doesn't seem appropriate with these items. Do you guys have any ideas for the best way to clean them up? Perhaps a chemical dip of some kind?
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
We submerge latch assemblies in lacquer thinner for a day to loosen grit and to remove any paint. Scrubbing clean with a gray scotch brite leaves a nice finish.
The Following User Says Thank You to 400 4spd. For This Useful Post: | ||
Thanks! I'll give it a shot.
Before installing it gets a shot of lithium grease on the moving parts and wipe down. New screws are the finishing touch. If you were doing a '68 and up (painted body color) my advise would differ. Your striker should also be unpainted.
The door hinges are cast aluminum? Had no idea they ever used aluminum hinges.
Yeah, it's a '66-67 only thing, I think.
64-67, I believe. My 64's appear to be cast too, and the repops I've seen look like my factory stuff.
John IG: @crawdaddycustoms YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos |
ALUMINUM
There were two types of hinges used on '66 & '67.
Steel & Malleable Iron (Pot/cast metal) Ther are a few old posts talking about years of use. Shown below is one of the cast hinges from my Bin.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 02-26-2024 at 07:17 AM. |
Thread Tools | |
Display Modes | |
