Old 08-08-2020, 05:24 PM
70badboy 70badboy is offline
Default Painting the grill on a 70 GTO question
I am redoing the grills on my 70 GTO and my question is. How do I paint the center part of the grill, since it is argent silver that goes half way the squares? Help please. Thanks Steve
Old 08-08-2020, 07:36 PM
I thought the egg crate was black and the surround was argent?
Old 08-08-2020, 10:00 PM
Formulabruce's Avatar
The front surface edge of the grille "egg crate" is Argent. To replicate this while the inside of the crate is black, I have used a special silver sharpie. This sharpie has no pocket clip and is supposed to be stored cap on, Point down. Takes time but a sweet job, easy to touch up after the dragon fly impact too ! This passed a judge at MACN as well.
The Following User Says Thank You to Formulabruce For This Useful Post:
Old 08-08-2020, 11:09 PM
Where did you get the special silver sharpie? Thanks Steve
Old 08-09-2020, 12:17 AM
Staples, BUT, these are usually sold individually, have real metal in them and NO CLIP on the cap. They are meant to be stored tip Down , so they work correctly as they have more than permanent ink in them.
You may see silver markers with a pocket clip on the cap , those are Not the ones you want for this job.
Good luck, have patience, and do not overlap too much. Wait till its dry to evaluate before any tune up work on it.
Old 08-09-2020, 09:24 AM
thanks Formulabruce, another question, What color of black is used on the egg crate? Thanks Steve
Old 08-09-2020, 12:01 PM
Originally it was "ABS" black.. No paint. I use Eastwood trim black paint if one is faded or needs work.
Old 08-10-2020, 11:03 AM
Hi, does anybody have the paint code for argent silver? Thanks Steve
Old 08-10-2020, 11:13 AM
Rally wheel paint for Camaro is Argent Silver
Old 08-10-2020, 11:20 AM
Hi Formulabruce, thanks. Just gat back home from going to Staples, all I could find was metallic silver ( #39109) fine point. Is this the correct marker? Thanks Steve
Old 08-10-2020, 12:07 PM
I just did my '68 a couple of weeks ago. I didn't find an argent that I was looking for but I had a can of VHT SP127 Universal Aluminum. Looked perfect to me.
Similar deal with painting everything black first and then masking off for the silver. The back half of every individual vane is black on the '68 also.
I had to touch up a few spots after this photo. For that, I sprayed the paint on a piece of glass and used a small brush and MORE masking tape. A LOT of masking on this deal... I mention that because if you can't find the marker, you might be able to do the same for the argent on the front edge. Small artist's brush with bristles cut almost all the way back to the handle or even one of those small sponge paint applicators you get at the hardware store in the paint dept.
Old 08-10-2020, 12:16 PM
Have a pocket clip on the cap?
That is how you tell, or I tell, I dont have mine in front of me.
Old 08-10-2020, 12:17 PM
I had to touch up a few spots after this photo. I sprayed the paint on a piece of glass and used a small brush and MORE masking tape. A LOT of masking on this deal...
I have used a Q-tip with the camaro rally wheel argent silver.
Your grill looks great!
Old 08-10-2020, 12:41 PM
It does not have a pocket clip on it.
Old 08-10-2020, 04:59 PM
That's the cleanest , cheapest way to get this done. . That's the correct marker.
Old 08-10-2020, 11:31 PM
That is the one I got at Staples today. All they had was a fine tip. I got my grilles tape up ready for paint. I am going out tomorrow to find some argent silver paint. Steve
Old 08-11-2020, 09:39 AM
Here are pictures of my grilles before paint
ID:	546885   Click image for larger version
ID:	546886   Click image for larger version
ID:	546887   Click image for larger version
Old 08-11-2020, 10:08 AM
What is the paint code for the Camaro rally wheel argent silver so I can check with the part stores? Thanks everybody for the help. Steve
Old 08-11-2020, 07:13 PM
Will this paint code work --- Ditzler DQE 8568 for the grille ?
Old 08-14-2020, 06:54 PM
D&R CLASSIC sells it in spray cans, maybe Ames does.
