Old 09-13-2020, 11:35 PM
ZeGermanHam's Avatar
Default Tricks for refurbishing door latches & hinges?
I'm getting ready to hang the doors back on the '66, but first I'd like to clean up the door latch mechanisms and the hinges. The hinges are cast aluminum, and have thick paint on them. The latches are just generally crusty looking. All were working fine without issue before disassembly, so I was planning to reuse them.
Media blasting doesn't seem appropriate with these items. Do you guys have any ideas for the best way to clean them up? Perhaps a chemical dip of some kind?
1998 BMW 328is (track rat)
Old 09-14-2020, 07:51 AM
400 4spd.'s Avatar
We submerge latch assemblies in lacquer thinner for a day to loosen grit and to remove any paint. Scrubbing clean with a gray scotch brite leaves a nice finish.
The Following User Says Thank You to 400 4spd. For This Useful Post:
Old 09-14-2020, 09:38 PM
Thanks! I'll give it a shot.
Old 09-14-2020, 10:59 PM
400 4spd.'s Avatar
Before installing it gets a shot of lithium grease on the moving parts and wipe down. New screws are the finishing touch. If you were doing a '68 and up (painted body color) my advise would differ. Your striker should also be unpainted.
Old 09-15-2020, 08:55 AM
dataway's Avatar
dataway dataway is offline
The door hinges are cast aluminum? Had no idea they ever used aluminum hinges.
Old 09-15-2020, 11:18 AM
Yeah, it's a '66-67 only thing, I think.
Old 09-15-2020, 06:12 PM
JC455 JC455 is offline
64-67, I believe. My 64's appear to be cast too, and the repops I've seen look like my factory stuff.
John
IG: @crawdaddycustoms
YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos
Old 09-16-2020, 06:34 AM
Jeff Hamlin's Avatar
Question ALUMINUM
There were two types of hinges used on '66 & '67.
Steel & Malleable Iron (Pot/cast metal)
Ther are a few old posts talking about years of use.
Shown below is one of the cast hinges from my Bin.
