Old 07-22-2020, 12:13 AM
webfoot's Avatar
webfoot webfoot is offline
Default 1962 - dash nut inserts
On the spring loaded square nuts, a few of the clips have broken and I fear the rest aren’t far behind. Is there a nylon nut replacement that will fit?
These are for the #8 screws that hold the dash to the housing.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 07-23-2020, 02:11 AM
webfoot's Avatar
Turns out they're just 8-32 cage nuts, nothing fancy, so I just ordered some new ones.
-Jeremy
Old 07-29-2020, 04:51 PM
webfoot's Avatar
I realize I'm just talking to myself, but replying only if it helps others doing a search.. the license plate nylon inserts fit perfectly and accept a #10 screw, which you can get with the same size head as the #8 used for the cage nuts. This doesn't elevate the dash bezel at all because this area of the bezel is already cast around the cage nut.
-Jeremy
Old 07-29-2020, 06:02 PM
tempest1964's Avatar
I don’t even own a Darksider, but I appreciate it. I talk to myself all the time. Sometimes I just don’t like my answers.
Old 07-30-2020, 05:38 AM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Great info. Thanks!
