Old 07-29-2020, 09:11 PM
Mark66 Mark66 is offline
Default "66 B body underhood insulation clips removal
How can I remove the existing underhood insulation clips on a 1966 B body without damaging them so that they can be reused?
Old 07-29-2020, 10:46 PM
242177P's Avatar
242177P 242177P is offline
Old insulation has got to go first. After that you can gently squeeze the barbs from
the side with like a pair of needle nose pliers until they cooperate. You *might* get
frustrated with an awkward clip, and compress it too much out of sheer frustration
(ask me how I know )
Old 07-31-2020, 01:30 AM
I was hoping to be able to remove some clips from a donor hood and reuse them on a decent hood that I have. But seems I will have to order new clips instead. Thanks for the head-up.
Old 07-31-2020, 02:00 AM
242177P's Avatar
You should be able to reuse them. You just can't get carried away like on the one that frustrated me
Old 07-31-2020, 02:08 AM
242177P's Avatar
Photo just to help you see what you're trying to squeeze
Old 07-31-2020, 12:50 PM
vertigto's Avatar
vertigto vertigto is offline
Very helpful image.
Old 08-05-2020, 10:26 PM
8LUG 8LUG is offline
Default clip removal
the tool.
Old 08-06-2020, 11:21 AM
Now that tools looks as if it might work. I know I have seen it before - and that it has a primary purpose unrelated to the removal of hood insulation clips - but cannot remember what it is called.
Old 08-07-2020, 07:06 AM
MAC Tools Clip removing tool BT 326
