Old 08-01-2020, 08:03 PM
GTOLou GTOLou is offline
Default where does the steering column plug harness go.
Man - I'm sure this is basic - but my other cars are a flat set of plugs that sit on the side of the column.
Does this curved set of plugs go under/over/to side of column?
Thanks!
Old 08-01-2020, 09:23 PM
curved steering column connector - just zip tie it in?
Old 08-01-2020, 09:51 PM
Scott Thelander's Avatar
no no no
there should be 2 tangs on the steering column that the ends of the plastic plug
slides into
Old 08-02-2020, 12:13 AM
Yes that’s correct. The tangs should be a couple inches up from the ignition switch and they will be located on the passenger side of the column.
-Jason
1969 Pontiac Firebird
Old 08-02-2020, 01:07 AM
Hikin Mike's Avatar
Unless it's like mine. I had to remove that flat connector years ago and use a non-factory plug due to bad connections. That was 30 years.
- Mike
Old 08-02-2020, 07:26 AM
lol..thanks - I'll look again.
Old 08-02-2020, 09:05 AM
So...here's a couple of pics for you rangers (everyone likes pics). I see no tangs - maybe not a factory column?
Are we talking the u-shaped deal on the end of the bracket that holds the column in? Has two holes on each end.
(pic of column is from passenger side - I can get drivers side too - but no mounting tangs on that side either)
ID:	546275   Click image for larger version
Old 08-02-2020, 01:10 PM
Sport69 Sport69 is offline
How's these?
ID:	546282   Click image for larger version
ID:	546283   Click image for larger version
ID:	546284   Click image for larger version
ID:	546285   Click image for larger version
Cholesterol Bad Adrenaline Good
Do it till your eyes bug out!
Old 08-02-2020, 01:13 PM
Thanks!
I can see by the purple wire that that's for your clutch neutral safety switch. Did you need the wiring schematic?
