Old 08-02-2020, 08:21 AM
J GLASGO's Avatar
J GLASGO J GLASGO is offline
Default Repo fan shroud
Anybody use this? Ames pretty much said it's junk.
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of!
Old 06-11-2021, 09:41 AM
grivera's Avatar
grivera grivera is online now
Reviving old thread with same question?
How about this one from Tamraz - anyone know quality? https://www.ebay.com/itm/333747351945
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 06-11-2021, 01:15 PM
JLMounce JLMounce is offline
I will my original AC shroud available soon. It's off the car now and an electric fan will be going in its place.
I should say that I don't see a part number on it and since I'm not the original owner, I can't 100% verify it's original, but it fits very well.
-Jason
1969 Pontiac Firebird
Old 07-15-2021, 11:19 AM
trmjr1 trmjr1 is offline
I spoke with the owner of Firebird Central about this very issue a couple weeks ago - that Ames said the repop was junk. He said the one he sells is very nice as did a long-time Pontiac NOS parts guy I know because I was looking for an original for my car and purchased his from Firebird Central. . Might check with Firebird Central.
1969 Firebird 400 Convertible
"We have got but one life here. It pays, no matter what comes after it, to try and do things, to accomplish things in this life and not merely to have a soft and pleasant time." - Theodore Roosevelt
"Light travels faster than sound. That is why some people appear to be bright until you hear them speak." - A father's words of wisdom to his children
Old 07-15-2021, 05:15 PM
Tarl Tarl is offline
The one Firebird Central sells is GM 9788883, it fits but the fan isn't centered on my new to me 68 firebird. The ~19 inch fan I have is like an 1/8th from the passenger side and about 3/4 to an inch on the drivers side and top. Might be my car though, the motor mounts are brand new. The engine looks a bit tilted to the drivers side, no idea how, but the DS side measures 14.5 inches from valve cover to radiator, and PS side measures 13.75... weird.
1966 Lemans convertible 455/5spd
1968 Firebird convertible 400/4spd
Need more Pontiacs!
Old 07-15-2021, 07:21 PM
muscle_collector's Avatar
how much are nos ones selling for?
Old 07-20-2021, 01:19 PM
RocktimusPryme's Avatar
I have one, its sorta fine but held in by zip ties at the bottom. I have a cold case which claims to be OEM style, but the aluminum tabs on the radiator did not at all seem to jive with the tab placement areas on the shroud. Who is at fault there I dont know.
Old 07-20-2021, 01:23 PM
I have a cold case and just removed the factory shroud 988883. The cold case tabs fit perfectly in the slots of my oem shroud.
-Jason
Old 07-25-2021, 10:44 PM
I’ll look at mine tomorrow. Maybe I’m doing it wrong. There are these J Clips that came in my hardware kit that I could never get to work right. I just kept bending the tabs. I was afraid I was going to break one off so I just stopped and zip tied it.
Old 07-26-2021, 09:57 PM
4dblnkldude's Avatar
It may not be you, the tabs are not rounded at the bottom to accept the shroud real well. I slid a phillips screw driver in the end and kinda worked it round. I'm 99% sure I have the original shroud.
Old 07-27-2021, 08:15 AM
grivera's Avatar
How did it work out for you? Also, what size fan do you have and is it an OEM radiator?
Will Rivera
