OHC-6 TECH Over Head Cam projects, questions and advice.
Old 04-30-2013, 07:35 PM
Jeff Hamlin's Avatar
Question '69 Part ID...
Gathering up the last of the '69 Engine bits and came across this bracket/strap that I have never seen before. Bolts onto the Atl bracket.
Anyone know what this holds?
Old 04-30-2013, 07:54 PM
Cammer-6 Cammer-6 is offline
what was on the end thats shiny?
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 05-01-2013, 05:36 AM
Rubber dip coating and the split is coated on the edges so it was there from the start.
I'm thinking based on location and with the insulation coat it was to hold the alt wire away from the manifold, I've just never seen this.
I've looked in some of my books and couldn't find anything like it.
Old 05-01-2013, 05:11 PM
might be right ,with an additional grommet in the forked part too
Old 05-01-2013, 05:12 PM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
Looks like to me it held a hose. Like a vacuum line perhaps to the breather valve on a smog pump? I'm grasping at straws with that though.
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
Old 05-01-2013, 10:24 PM
camerjeff camerjeff is online now
Jeff,
I second the straw grasp of a Non Power Steering A.I.R. car. I have owned 5 69's, 1 Tempest, 1 Lemans, and 3 Firebirds and have never seen anything like it, but non of the cars were A.I.R. equiped, and only the Tempest was a non pwr steering car.
Old 05-02-2013, 05:42 AM
OK Thanks guys, I just thought maybe it was something "I" hadn't seen before.
I'll just add it to the Whatsit box
Now to something else I wasn't aware of and/or have never noticed until recently.
I now know what it is but figured I'll throw it out there.
Round 2 of whats it...
Old 05-02-2013, 10:44 AM
A blurry picture! What do I win?? =D
Old 05-02-2013, 06:48 PM
brake booster vacuum line support
got any extras?
that would go great with the new brake booster tubes I repro
Old 05-02-2013, 06:53 PM
Winner!
Sorry I do not have any spares.
I am working off factory install sheets to recreate something I had never seen before.
The NOS booster that just passed on epay had the sheets, showing the OHC set-up.
Learn something new everyday
What are you getting on the tube ?
Old 05-04-2013, 11:51 AM
OHCSprint67 OHCSprint67 is offline
Thumbs up Power Brake Booster Bracket
This the factory install diagram Jeff had referenced.
I took a few photos of the part with a tape next to the bracket.
Unfortunately I wasn't able to keep it, but should be easy to duplicate.
Name:	Jan and Ron.jpg
ID:	322106   Click image for larger version
ID:	322107   Click image for larger version
ID:	322108   Click image for larger version
67 Lemans OHC 6 Sprint Clone T-5 5 speed convertible
Old 05-04-2013, 09:34 PM
I had (have)one of those kits too and used the tube as a template for my repros.
Jeff,lemme look and make sure I still have all the fittings.
IIRC the flare fitting was replaced with a compression one.
Looks the same when installed.
