Old 09-16-2020, 01:16 PM
Stan Weiss's Avatar
Stan Weiss Stan Weiss is online now
Default Pump Gas HP from 10 years ago
So what would a list like this look like today?
Stan
Got this from PZ. http://www.pontiaczone.com/forum/sho...=25451&page=13
Looking to make a list of the fastest pump gas N/A pass made so far. That we know what the record is and we all have something to shoot for. Also you could see where you stand on that list.
OK, just for fun I added a new figure and ranking to the list. I used http://www.dragtimes.com/horsepower-...calculator.php for the info provided with each car to get an idea of the "power ranking" if we cheated and said that air and track conditions (and accuracy of info) were equal among racers.
Just thought I would update the list
1........ 820hp – slowbird (ec) 9.45 @ 141.46 3600lbs 496CI Barton HP
2........ 780 hp - Marcel (SD Performance) 9.939 136.03mph 3920 lbs SD Wide Ports 535 CI
3........ 761 hp - Walter L. 9.73 @ 136.9 weight 3670 lbs... 525 CI..Dan Barton KRE D-Ports...corrected 40 degree whether
4........ 754 hp - Brian Rock 10.16 @ 136.1 3920 lbs. 496 IAII ported High ports (350 ish) standart pushrod location. Tagged and insured.
5........ 753 - Gach 9.45 140 mph 3360 lbs Wide Port E-Heads 505 CI
6........ 751 hp - Robin Roberts 9.50 3450 lbs Ported CV-1's 535 CI (used 138 mph as a guess)
7........ 741 hp - Frank Gostyla 9.96 137mph 3700lbs Unported Tiger Heads 535 CI
8........ 732 hp - Aaronman 9.45 @ 142mph mph Wide Ports 468 CI 1968 Firebird 3200 lbs
9........ 727 hp - Sean Pickett 9.52 @ 138 mph 3350 lbs 380 ported High Ports 510 CI
10...... 701.3 hp - Estep455 9.21 147mph weight 2800 lbs E-Heads...tube Chassis *** registered.
11...... 700.9 hp - Jeff (mysticmissle) 9.86 135mph 3520 lbs unported CV-1's 511 CI
12...... 698 hp - P-Dude 9.78 @ 136 mph 3425 lbs ? 340 cfm SD Performance E-Heads 535 CI
13...... 697 hp - 69Goat1 9.90 ?? mph 3525 lbs Ported E-Heads * 462 CI *** registered. (assuming 135 mph)
14...... 695 hp - Jay Johnson (New Orleans) 340 ported KRE dports,done by KRE 9.20@146mph 2800Lbs. **
15..... 694 hp - 79TA455STROKED 9.81 @ 138 mph 3350 lbs Butler Wide Ports * 462 CI stock block
16..... 629 hp - Eric Nau 9.99 @ 133.34 66 GTO 3280 lbs IAII 535 std PORT E-HEADS 10.25 TO 1 3.73 rear So far it now has 3.89 gears and a corrected converter
Pontiac Pump Gas List
Old 09-16-2020, 02:23 PM
slowbird's Avatar
slowbird slowbird is offline
Longer lol
ET/HP hasnt changed much
Old 09-17-2020, 06:10 AM
steve25 steve25 is offline
Stan your missing my buddy's car.
67 GTO, 3200 lb race weight, 505 cid, ported (340 cfm) non wide port E heads, 14.5 comp, 9.13 ET, 143 mph @ NJ Island raceway.
Hp level would seem to be 750.
Old 09-17-2020, 12:29 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
Are these pump gas ( 91/93 octane) applications ?
Old 09-17-2020, 09:42 PM
slowbird's Avatar
Yes pump gas 91/93 octane engines
Old 09-17-2020, 10:12 PM
Gach's Avatar
Gach Gach is offline
I’m sure they’ll be a few more added to this list.
Old 09-17-2020, 10:28 PM
slowbird's Avatar
Mine can be updated to 9.05@146.5. The calculator in the first post does seem to work so no idea what it shows for hp
Old 09-18-2020, 12:27 PM
Stan Weiss's Avatar
Brian,
Does it still weigh the same?
I have gone to a different method to estimate / calculate the HP.
Stan
Old 09-19-2020, 08:56 AM
slowbird's Avatar
Originally Posted by Stan Weiss View Post
Brian,
Stan
Weighed 3500-3550
Old 09-19-2020, 09:24 AM
Stan Weiss's Avatar
Weighed 3500-3550
Brian,
Thanks. I used 3525.
Stan
Old 09-19-2020, 09:34 AM
Formulajones's Avatar
Is this a HP list or an ET list? Or an estimated HP list based on ET?
Bischoff built dad's pump gas engine, with actual dyno numbers of 724hp and 764 tq with a conventional old set of Edelbrock heads on it, on 91 octane. True street car that is driven everywhere.
Still working on ET's as the rest of the car keeps getting wholesale changes.
https://youtu.be/XqEydRRRwqE
Old 09-19-2020, 09:49 AM
Stan Weiss's Avatar
A estimated HP list based on ET, MPH and weight.
What is your Fathers name? I can add him as dynoed HP..
Stan
Old 09-19-2020, 10:00 AM
Stan
Okay gotchya thanks Stan
Larry Jones.
His best ET to date is 10.89 at 125 with a converter so loose the shift light stayed on the entire pass and occasionally bangs the limiter. Made 3 converter changes, a rear gear change and several other things. I suspect the car will go quicker when everything is right. Stock suspension, small 275 radial tire etc.. Weighs 3980 with him in it.
Old 09-19-2020, 10:29 AM
Stan Weiss's Avatar
Larry Jones.
OK he has been added. Is there a link to a build thread for his engine where I can get some more information?
Thanks,
Stan
Old 09-19-2020, 10:39 AM
Thanks,
Stan
Let me dig and find that Stan. It's in here somewhere.
Edit: See if this works? I'm not the best at linking stuff
https://forums.maxperformanceinc.com...d.php?t=788997
And here is some dyno video
https://youtu.be/5WswK-m-zIA
There was another build thread (I thought) with pictures and more detail but I haven't found that yet. It's basically 10.84:1 compression, old set of round port Edelbrocks with bathtub chambers (not wideports) Tony ported to 360 cfm. Victor intake that he modified in his words to kill some bottom end torque, knowing it was going to have a bunch. It's an MR1 block 4.350 bore, with a 4.750 Ohio crank. Dyno'd with the chassis 2" Hooker headers used on the car and runs on 91 pump.
Old 09-19-2020, 03:43 PM
Dragncar Dragncar is online now
I remember that list. It used to be "the" list.
Old 09-19-2020, 04:13 PM
Stan Weiss's Avatar
Thanks. I have added some of that information to the list.
Stan
Old 09-20-2020, 10:12 AM
Thanks Stan. Never knew there was such a thing. It'll make dad's day.
Old 09-21-2020, 01:29 PM
Stan Weiss's Avatar
Glad I could help made your dad's day. Thank you for the information that you were willing to share.
I have also added a few engines to the bottom of the list for which I have no track data.
Thanks Steve C. for the updated HP and cam information on your pump gas engine.
Stan
Old 09-21-2020, 08:10 PM
ta man ta man is offline
Darby Otto should be on that list.
