Old 09-18-2020, 07:38 PM
GoGoat GoGoat is offline
Default Reset TH400 kds
How do I reset TH400 kick down switch? It is on the accelerator pedal. Part #PZ00415 from OPGI. Thanks for great website
Old 09-19-2020, 03:15 AM
lust4speed's Avatar
If it operates as the stock switch, just push it forward in its bracket and then floor the gas pedal and the switch holder will ratchet to the proper position. You should be able to hear the clicks as it moves back the required amount.
Mick Batson
Old 09-19-2020, 09:13 AM
Default Defective switch?
Maybe I have a defective switch, It acts like it was already set at midpoint. Bag was stapled shut. Just moves to 2nd half of travel, I need it to activate before mid point. I might try to post pictures.
Old 09-19-2020, 10:06 AM
Here are pics.
ID:	549894   Click image for larger version
Old 09-19-2020, 11:23 AM
Kenth's Avatar
Kenth Kenth is offline
You need to pinch the slider and pull it out as far as you can to reset the switch.
It will adjust itself at next WOT.
Hope this helps some.
Name:	Inkedkickdown switch_LI.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 09-20-2020, 08:32 AM
Default Thanks Kenth
I knew there had to be a simple thing to release the slider. And I knew someone on here would know. Thanks again
Thread Tools
Display Modes
