Old 05-22-2021, 09:03 PM
Mike S's Avatar
Mike S Mike S is offline
Default Ign. box analog or digital
My old Mallory box was acting up today, Shopping for a new box. So many choices. A few recommend the MSD grid. I only need a start retard, rev control for launch, high speed rev control and one stage retard.
Any recommendations?
Old 05-22-2021, 09:16 PM
GTOGEORGE's Avatar
I think I still have a Mallory pro mod ignition system I’ll let go for about $175 with coil
Hyfire 7c
GTO George
Old 05-22-2021, 10:10 PM
GTOGEORGE's Avatar
Pic
GTO George
Old 05-22-2021, 10:54 PM
ID67goat's Avatar
ID67goat ID67goat is offline
I am not a hardcore racer, but have used the MSD 6al-2 programmable box. Just lock out the distributor and then setup the timing curve, rev control etc on the laptop. Power grid looks,like,the same thing but with way more adjustability and features.
6al-2 programmable probably would cover what you need, but the power grid gives you lots of room to grow.
Old 05-23-2021, 01:51 AM
69Goat1's Avatar
69Goat1 69Goat1 is offline
I went with a grid...nice features...
Old 05-23-2021, 02:46 PM
Mean Green's Avatar
Mean Green Mean Green is offline
MSD 6530
www.lancablingsolutions.com
Old 05-23-2021, 02:54 PM
GTOGEORGE's Avatar
Originally Posted by Mean Green View Post
MSD 6530
Wow.....$460
GTO George
Old 05-23-2021, 08:10 PM
Mike S's Avatar
I have had luck with the Mallory hyfire VII for close to 10 years. It started last summer cutting off, Have to kill power to the box before it will start again. I installed a fan blowing on it and it helped. Now it started acting up again in this 90 deg heat. I have it mounted inside on the firewall. They don't make it anymore.
I am look for something simple to adjust. Thinking of the old school MSD 7AL.
Old 05-23-2021, 10:28 PM
GTOGEORGE's Avatar
Simple......old school, that would be the way to go but now a days with trans brakes, delay boxes, air shifters, data recorders, weather stations it’s tough. I like old school just foot braking it.......olden days!
I got a crane hi-7 with a dec9000 pretty simple but not like the Olden days....for sure!
GTO George
Old 05-24-2021, 08:29 AM
Mr Anonymous's Avatar
my go-to is the MSD Digital 6, easily meets your requirements. As long as you use quality wiring and connectors, it will give you zero problems from my experience.
I saw one guy going on about how much of a POS his box was, well, he had scotchlocks and such ... thats a bad data point instantly.
Clutch Guys Matter
53 Studebaker, 400P/th400/9"
64 F-85
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
Old 05-24-2021, 06:13 PM
AG's Avatar
AG AG is offline
X2, my Digital 6 has worked flawlessly for 8 years. Two rev limiters and a 20 degree start retard.
Old 05-24-2021, 11:32 PM
Mike Davis's Avatar
X2 on the Digital 6.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 05-24-2021, 11:49 PM
cgeise's Avatar
cgeise cgeise is offline
to be honest the start retard has cost me more flex plates than I can remember---
