Old 09-11-2021, 11:06 AM
Lifetime Goat's Avatar
Lifetime Goat Lifetime Goat is offline
Default Need standard crank pulley for ATI damper.
I am trying to find a 3 bolt crank pulley that fits a Pontiact ATI damper but is not an under drive pulley. I have a 2 grooves BBC pulley but that does not extend enough and I would need a spacer. Any suggestions appreciated.
1971 GTO Convertible 455 #64 Heads, HO intake and carb with MSD HEI, RAIII exhaust manifolds and 3:55 posi
Old 09-11-2021, 11:43 AM
Extend enough to match the water pump pulley, or line up with the other accessories?
More info needed, please.
ps I have been running ATI Dampers (best made) for many years. The water pump pulley location is key, the rest can be shimmed.
Old 09-11-2021, 12:19 PM
chuckies76ta's Avatar
I to have the ATI balancer. I agree best one made. I just took my previous 4 hole pulley and aligned it on the balancer and drilled 3 new holes. Has been fine. I had a custom spacer made for shimming my water pump pulley. I also installed a MSD crank trigger which caused me to shim everything forward.
I believe Butler sells a 3 hole pulley that Ram air restoration sells or manufactures.
One thing to watch is when you install the balancer, I had to clearance the timing cover a bit.
Old 09-11-2021, 01:33 PM
Ram Air Restoration has factory aluminum pulleys they can drill for 3 holes . Before that I also had a stock one I drilled. I found a SBC ring(like the one on our balancers on the outside) and used it for a template.
And yes the timing cover will need clearancing.
Old 09-28-2021, 07:13 AM
grandville455's Avatar
Chuck Where did u grind and how much?
Darby
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 09-28-2021, 08:03 AM
I ended up drilling three new holes but due to proximity I had to use the allen head bolts and notch the washers. All good now and working well.
Old 09-28-2021, 09:40 AM
Hi Darby: I had to remove material of the timing tab and a bit of the bottom tabs. I drilled a couple 6/32 blind holes and tapped them then had my son make me a custom pointer for TDC.
Old 09-28-2021, 11:52 AM
Thanks for the great Pic!!
Darby
