Old 10-18-2019, 09:22 AM
goatheaven goatheaven is offline
Default Is it worth upgrading to RAM AIR IV Aluminum Heads?
Thinking about upgrading to Edelbrock RAM AIR IV Aluminum Heads this winter.
My set up currently is 455 bored .30 over, TRW Forged Pistons, 4X Heads with Comp cam ram air V and Nodular Crankshaft 9799103
Who is running 455 with aluminum heads? How much horse power would I be gaining? Can I run on pump gas 87 or 93?
Thanks in Advance for feedback
charlestown chiefs t-shirts
Old 10-18-2019, 05:39 PM
Tom Vaught's Avatar
Boost Engineer
Stock RA-IV cast iron heads flow 230 cfm at 25" of Test Pressure.
Edelbrock Aluminum RA-IV Heads will flow 280 cfm at 25" of test pressure STOCK and are lighter.
50 cfm increase per port does make a difference on an engine.
Tom V.
Old 10-18-2019, 06:25 PM
Default Thanks for reply
Thanks for reply. Any idea of about what the compression would be? And how it would run on 87 octane? Horsepower increase?
Old 10-18-2019, 07:06 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Horse power and 87 octane are maybe the two words I haven't read in 20 years on any performance car forum. You'll see a 21% increase in air flow so if you're air fuel ratio is the same you'll notice a power increase.
I wouldn't bother running anything lower than 92 or 93 if you're looking to make power, have a heavy vehicle and throw some timing in it (36 etc). You have more to lose then 30 cents per gallon saved.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct at 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump
Old 10-18-2019, 07:27 PM
Haha, Not trying to be cheapskate at all. Current set up runs great on 87. Was just curious, I'm a fairly stock guy and my first build, and want to gain some more power and performance.
Old 10-18-2019, 08:11 PM
charlie66's Avatar
Is this motor boosted??
My Half AN Injun.....
Old 10-18-2019, 08:16 PM
No, any ideas? Just looking for fast street car
Old 10-18-2019, 09:30 PM
firechicken's Avatar
firechicken firechicken is offline
Put this in the street section if you want more input than you can handle...
Old 10-18-2019, 10:16 PM
thanks will put n street section thanks
