Old 11-07-2019, 02:40 PM
Stan Weiss's Avatar
John,
Do you know if anyone has had a Pontiac on a Spin Tron?
Stan
Pontiac Pump Gas List
  #42
Old 11-07-2019, 03:03 PM
johnta1 johnta1 is online now
If the push rod angle causes valve train problems and does not let the engine run in the RPM range it needs to the flow is of no use.
That's true especially with your 'If'.
But doesn't answer my question on John's pushrod angles or others running the wide ported eheads?
They can be pushing a lot of rope too.
  #43
Old 11-07-2019, 03:18 PM
Stan Weiss's Avatar
John,
Again what RPM are they turning? You know how loads go up with the increase in RPM they are not linear.
Stan
  #44
Old 11-07-2019, 04:59 PM
I don't know?
Langer would know, the ECM boys would know?
I'm sure it is a lot more than I run.
  #45
Old 11-07-2019, 05:09 PM
Stan Weiss's Avatar
I don't know?
John,
I don't have any valve train calculations. But if I use piston, rod, and crankshaft calculation, with the only change being RPM. @ 9200 RPM the load is about 50% greater than @ 7500 RPM.
Stan
  #46
Old 11-07-2019, 06:45 PM
Dragncar Dragncar is offline
Originally Posted by GTOGEORGE View Post
Maybe Justin will think about Warp heads now that Tommys car is performing so well!
GTO George
Then it wouldn't really be a Pontiac. Warp deals are "sort of" a Pontiac.
Besides, he is a Butler guy. Those CV-1s are never gonna see the light of day on that 70 GTO.
  #47
Old 11-07-2019, 07:21 PM
Stan Weiss's Avatar
Why is that?
Stan
  #48
Old 11-07-2019, 07:31 PM
slowbird's Avatar
slowbird slowbird is online now
Originally Posted by Stan Weiss View Post
Why is that?
Stan
Close minded
  #49
Old 11-07-2019, 08:51 PM
GTOGEORGE's Avatar
If it bolts to a Pontiac block it’s a Pontiac, get over it!
GTO George
  #50
Old 11-07-2019, 09:08 PM
Scott Roberts Scott Roberts is offline
It's a subjective issue... I personally would be comfortable calling anyhead that bolts to a Pontiac block a Pontiac... however! Some are more traditional and will only accept it as a Pontiac if it is layedout like a head PMD produced... there is no right or wrong opinion...its just that, an opinion...
  #51
Old 11-07-2019, 09:44 PM
Stan Weiss's Avatar
Oh traditional! Just where does that end? Pontiac ever offer roller lifters? Pontiac ever offer shaft rocker arms? How about changing the placement of the lobes on the cam and firing order? How about raised cam? Shouldn't the cam location be fixed?
I believe it should be all or nothing and am for the all side.
Stan
  #52
Old 11-07-2019, 10:01 PM
Stan
Lifters and cams are not changing the layout... just upgrading the PMD same design.... but hey, be as close minded as you want Stan
  #53
Old 11-07-2019, 10:12 PM
mgarblik mgarblik is offline
Originally Posted by John Langer View Post
If I was running a high boost application, I would want my push rods to be as straight as possible. The size of the hole of the intake port would be an afterthought. That's just me though...
Exactly why we are running a Ram Air V layout. Straight pushrods, stout rigid simple inline valvetrain. We have been 11,300 RPM under load with no damage. (by accident when we had a little transmission failure, on the 1-2 shift.). Normal trap RPM is 8700-9000
  #54
Old 11-07-2019, 10:24 PM
Stan Weiss's Avatar
Scott,
LMFAO
Reading comprehension! Please work on it.
Stan
  #55
Old 11-07-2019, 10:38 PM
You showed your true colors stan... lower case on purpose...
You stated your opinion then bitched out with a catch all...
  #56
Old 11-07-2019, 10:54 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Pontiac Power!
First Pontiac powered street car in the 7's
7.940@170.84. 3460#s
  #57
Old 11-07-2019, 10:59 PM
Stan Weiss's Avatar
Scott,
LMFAO
Stan
Scott,
I do it did not work the first time and am sure it will not work this time. But nothing lost trying again.
I have read enough of your posts so I know what is going on.
Stan
  #58
Old 11-07-2019, 11:19 PM
Scott,
Stan
Please Stan...tell us all what is "going on"... we are all ears..
  #59
Old 11-07-2019, 11:26 PM
Scott,
Stan
I have shared everything we did with the DirtyBird.... stroke, bore, cam specs, rod length, head work, overdrive, weight, bearing clearance, valve size.....you name it....what have you offered?
  #60
Old 11-08-2019, 03:03 AM
GTO George
That head, the Warp 6 was based on some Chevy or Ford head. I forget which one. But once that is done the engine will have the performance characteristics of that engine (minus the big bore) Whats beneath it are just a bunch of pistons going up and down and the rest just has to stay together and hope the oiling system can keep up too.
I mean, its fine if that is what you want to do. But we race Pontiacs because we want to not be like everyone else and to play the underdog. Pontiac heads get weight breaks in certain classes for a reason. Put their BBC head on and you loose that and do not get the fat bore to help either.
A Pontiac has the center ex BS, siamesed intake runners, crap oil system and we deal with it. Or, a RAV is a Pontiac but not really better unless blown.
Heads like Langers are still a Pontiac IMO. Still have the center ex BS to deal with and siamesed intake runners.
