Old 11-11-2019, 09:46 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Default Crank trigger vs Distributor Ignition
Looking for advise, Advantages of a Crank Trigger over my MSD distributor. I acquired a crank trigger set up for the 535 I'm building. But what is the advantage over a traditional distributor? Is it just in adjustability? This will be a sometimes street driven and drag race set up. If its worth it I could switch my current 474 over to it. Any disadvantage to running it on the street where occasional rain/puddles may be involved?
Old 11-11-2019, 10:20 PM
Mark G Mark G is offline
I drive on street with a crank trigger never a problem timing is always rock solid …
Old 11-11-2019, 10:26 PM
Half-Inch Stud's Avatar
Dizzies may have Timing bounce due to Cam twist & dizzy gear lash. Yet dizzy has Mech & Vac ADV.
Old 11-11-2019, 10:31 PM
Dragncar Dragncar is offline
Ken Brewer back when he was in business told me a crank trigger was worth 7HP in his dyno testing. He owned a dyno.
Old 11-12-2019, 02:31 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Weather doesn't bother crank triggers.
The basic advantage is very precise ignition timing.
I like the combination of a crank trigger with a Crane TCU on the Pontiac in my GMC- setting up the advance curve and vacuum advance without opening the hood is convenient.
Having said that; I must admit that I probably wouldn't have bothered with it. Except that the variable cam phasing I built (and tested) needed the ignition synchronized with the crank, not the cam. [The cam drive gears were too noisy for a street machine, so I shelved it. I hope to eventually get a set of helical gears cut and try again]
Old 11-12-2019, 07:59 AM
chuckies76ta's Avatar
Scott, hope it's ok Hijacking your thread. Question to do with Balancer bolts.
If installing a Crank trigger, Belt pulley, and Vacuum pump pulley on Crank snout, what size bolts should a guy go with? I've seen the 4 bolts loosen up. I actually had a friend loose his pulley on the track. He took his Balancer to machine shop and drilled and tapped for 3/8".
So, I believe the 4 bolts are 5/16". Seem to small. opinions?
Old 11-12-2019, 10:45 AM
No problem with hijacking, I'm happy for any info shared. I am using a Inovations West Balancer that has the magnets made into the balancer. One of the reasons is so I wouldnt have to use a bolt on ring for the magnet. I didn't want to have to re-do all the pulleys spacers for the alternator and vacuum pump.
Old 11-13-2019, 07:46 PM
Thanks for the info Scott.
Charles
Old 12-01-2019, 10:35 AM
bigdogmark bigdogmark is offline
Do all the stock pulleys still line up running this damper?
Thanks, Mark
Old 12-01-2019, 08:04 PM
I believe they will. I havent had it in my set up yet. The tech guy at Inovators West said they would.
