Old 11-13-2019, 06:49 PM
ponchorob ponchorob is offline
Default 670 head valve size mystery
....got 670 head measured intake and exhaust valve size ..exhaust 1.77 but intake measured 2.07....with 5.05 length..... whats going on here ?
Old 11-13-2019, 10:34 PM
A.W.Dille A.W.Dille is offline
My 670 heads have the 2.11-1.77 valves. Only thing I can figure is someone may have installed the 2.05 intake valves for use on a 350 engine due to the smaller cylinders. But that is just my guess.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear
85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book.
87 F350 6.9 4 speed dually
A poor man has poor ways.
Old 11-13-2019, 11:05 PM
Half-Inch Stud's Avatar
Perf trick: didn' some folks turn their Valve head diameters down to match the Seat contact?
I lacked the fixtures to do it, but sure tried at the hobo level on some junk valves.
Old 11-14-2019, 02:08 AM
The heads cams offiziell a 428 engine
Old 11-14-2019, 02:09 AM
The heads came off a 428
Old 11-14-2019, 07:30 AM
steve25 steve25 is offline
The first thing I need to ask is if the valve has a 30 degree seat?
Many Milodon valves that people I have done work for have supplied me with that where said to be 2.11" checked in at 2.10", and even factory valves have been that way at times.
When your 2.07" valve is at normal operating temp it will be much closer to the size it should be and not overrun the seat and leave you with a narrow seat that may not seal up well.
Another point is that a 2.07" valve helps to unshroud that 670 chamber that needs all the help in that dept that it can get above .430" lift, yet that size valve will not cut into that 670 heads great low lift flow especially at the .250" to .320" lift range.
Old 11-17-2019, 09:21 AM
taff2's Avatar
taff2 taff2 is offline
I believe the 2.08" intake valves I used were Ford size, Manley or Milodon IIRC.
Old 11-18-2019, 08:02 AM
So you you are running 45 degree seats?
