Old 01-15-2024, 10:15 PM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
Default Brake Pedal Return Spring
I am redoing all the brake hardware on a manual disc/drum (pads & shoes, wheel cylinders, master cylinder, etc....) and the rear Strange C-Clip eliminator kit on my 69'. Changed the latter over to studs versus bolts.
I realized the brake pedal does not return to an UP position. Is there supposed to be a return spring such as attached in the links below?
I have read conflicting information regarding its usage. 1) Manual vs. Power brakes and 2) Auto versus Manual transmission brake setups.
Thank you.
https://www.firebirdcentral.com/1967...p/ppd-831b.htm
https://www.npdlink.com/product/brak...on/154374/1754
https://www.heartbeatcitycamaro.com/...GM%23-3850084/
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
Old 01-16-2024, 03:33 PM
hojs69's Avatar
If this helps others.....
There is also reference in the factory manuals to Cruise Control vehicles having the spring. See related pic below.
Name:	Brake pedal return spring (1).jpg
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
Old 01-16-2024, 08:13 PM
AG's Avatar
AG AG is offline
My '68 with manual drum brakes has one.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
