Old 09-26-2021, 10:02 AM
Bill Hanlon's Avatar
Bill Hanlon Bill Hanlon is online now
Originally Posted by 65sport View Post
So who are you challenging ?
Kenth's statement about vacuum advance at 4500RPM.
He implies that there would be 20 degrees of vacuum advance applied at that engine speed. He also states that vacuum advance starts at 8-10 in/hg vacuum. I believe that the only way to get that kind of vacuum at 4500 RPM is either:
a. no-load (holding 4500 RPM with the clutch pushed in, why do this?)
b. no-load (accelerating past 4500 RPM , then closing the throttle)
In my opinion, maintaining 4500 RPM under load (especially in high gear) will require enough throttle opening that the 8-10 in/hg required to begin vacuum advance will never be reached.
Old 09-26-2021, 04:00 PM
Kenth's Avatar
Kenth Kenth is offline
If you want to know what is going on with vacuum advance at all rpmīs and driving situation just connect a vacuum gauge to the intake at a full manifold source via a long hose so you can watch wile driving.
Simple as that.
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
