Old 04-14-2009, 05:42 PM
J GLASGO's Avatar
J GLASGO J GLASGO is offline
Default WANTED 70-74 FORMULA LOW MILE
ALRIGHT MY 74 FORMULA WANTED AD IS NOT GOING TOO GOOD.ANY NICE RUSTFREE FORMULAS 70-74 OUT THERE? 350,S ARE FINE.
Old 04-16-2009, 10:45 PM
fearless100 fearless100 is offline
I have a 26 26 1970. I guess anything is for sale for the right price? 85k original miles and fully restored last year and 100% stock.
Old 04-17-2009, 06:06 PM
J GLASGO's Avatar
Thanks for the response,but i am sure i can not afford your car.I am looking for an unrestored low mile car.That sounds like a killer car,though.
Old 04-18-2009, 04:05 PM
cdnroundport cdnroundport is offline
Default 74 Formula
John have you seen this?
http://cgi.ebay.com/ebaymotors/Ponti...RCHQ3aUSQ3a102
Old 04-18-2009, 07:15 PM
Held for Ransom's Avatar
I could look at it for you if it's still available (only about 15 mins. from my home). And, it's been on eBay before.
Old 04-18-2009, 07:41 PM
J GLASGO's Avatar
I did not see it.I am going to try to get a phone number.Fire Coral bronze with 4-sp and no ac is as good as it gets for me.I know,i am sick,but i love that color! Thanks!
Old 04-18-2009, 10:44 PM
I still have Brian's number.
Old 04-19-2009, 08:37 AM
J GLASGO's Avatar
If Brian is the owner of the car,i would like to talk to him,if its still available.I could never understand how someone could put a car for sale on ebay with no phone number.Have you ever seen the car?
Old 04-19-2009, 02:17 PM
No. I tried to see it when it was up for auction in Feb., but I got too wrapped up in projects to get back to him. And, yes, Brian is the owner.
Old 04-19-2009, 02:59 PM
J GLASGO's Avatar
Just talked to him,and he is going to send some undercarriage pics.It looks to have a decent body,but we,ll see.
Old 04-22-2009, 05:26 PM
Any word?
Old 04-22-2009, 06:34 PM
J GLASGO's Avatar
I am still waiting for the undercarriage pics.If it looks good,i would be willing to pay you to look at it better,as it is too far for me to pick it up.It would be a sight unseen deal,and have it shipped.
Old 05-06-2009, 09:42 PM
74 SD455 Formula 74 SD455 Formula is offline
Any word?
HFR,
Did you happen to know anything about the Green on Green 1974 350 Formy that was on E-Bay that recently closed out ? The car was located in Cannon Falls, Mn.. The E-Bay seller's e-bay name was MR. Superduty...
Old 05-07-2009, 07:27 PM
No, sorry. Except that the eBay auction said something about Virginia (I think) title.
Old 06-02-2009, 12:08 PM
MoJo's Avatar
MoJo MoJo is offline
This is the ad I have on Craigs list in Fort Worth, Texas
1972 Pontiac Formula 400 / Th400 Automatic with a ton of extras. This is not a Clone but a RARE factory Formula. 1972 was a GM strike year. The Firebird production numbers were low. I have the original th400 transmission and 400 engine and rear-end pulled. The current engine installed is a High Performance 1974 462 CID / TH400 Trans / 3.73 POSI Rear-end built for Xtreeme Excitement. (See Notes Below)
The Car is a Texas car and the body metal is in great condition for 38 years old. The car is un-restored so it needs cosmetic TLC. It has been garaged but still needs care.
She needs seat covers, headliner, the dash is cracked, carpet is original, Fiberglass hood in good shape. Whole car needs painting. It had the vinyl top removed a few years ago and the body guy that primed the top let the paint run down the rear quarters, (long story) so the rear of the card is in primer. I have a set of original Honeycomb wheels that go with the car but not mounted. The mounted wheels are chrome with good but old tires. I have the original a/c components removed. All of the accessory brackets are here but not all installed due to the engine swap. There are misc spare parts with the car(too many to detail) ****As a bonus, I will sell the car with a 18' Steel Deck Dove Tail Car trailer with electric wench and toolbox( needs tires) ***.
Notes:
The current 462 engine installed:
Ø 1974 455 bored/honed to .035
Ø Zero decked
Ø HardBlok filled to bottom of freeze plugs only
Ø ARP studded main caps.
Ø BOP Viton rear main seal
Ø SRP Flattop Pistons with Speed Pro file fit rings (gapped .20)
Ø Clevite 77 rod and main bearings
Ø CAT Forged H-Beam Rods(floating pin)
Ø CAT Full roller rockers 1.5 ratio
Ø Stock Crank 10/20 w/ balanced rotating mass
Ø #16 heads 80 cc chambers, I/E port cleanup and intake matched to Felpro1233 gasket.
Ø SS RA4 valves, (Ferrea #F5063&F5066), CompCam 995 springs with matching retainers, 10 degree locks
Ø Competition Valve/Seat angles per Jim Hand specs ,
Ø 15-degree valve face cut towards the stem included
Ø Viton positive I/E valve seals
Ø ROL HP Racing head gaskets (.040 crush)
Ø ARP Head Bolts
Ø Ultradyne Solid Flat Tappet Dur243/251 @ 50, Lift .518/.530 @ 1.5 110 LSA
Ø Cloyes full roller timing set
Ø Melling HP 80 psi oil pump w/Oil Filter bypass plugged
Ø K&N Oil Filter
Ø Fuel pump boss blocked
Ø Holley Blue fuel pump/Regulator through stock lines.
Ø Galley plug drilled .030 for distributor oiling
Ø CAT Performance balancer damper
Ø Edlebrock Performer intake and 1973 Q-jet
Ø 1.75 Hooker Headers
Ø TH400 Trans with 3K Converter
Ø Stock 3:73 Rears, 8.5 Chevy Posi Rear end
**Over 5k invested in 462 Engine
Suspension is original
A balanced crossover dual exhaust system is installed and flows through a single Dynamax welded dual in/out muffler in stock location.
Orig Pontiac 400 Engine (pulled and stored)
• '72 400 bored .030 over (406cid)
• Original 400 Crank Std/Std
• Forged TRW pistons with Speed Pro Rings,
• Summit 2802 cam (224/234 duration@.50, .465/.488 lift, 114 LSA and is a hi-lift version of the Pontiac 744 cam)
• Stock rods polished and Shot-peened with ARP bolts,
• 1970 #13 heads (80cc) Lightly ported and gasket matched by owner, hardened seats, SS Valves, Comp Cam Springs, Adjustable stamped steel 1.5" rockers,
• Stock Iron Intake, Q-jet and mechanical fuel pump
**Original Th400 and Rear-end are part of the deal Both need servicing.**
I am pricing this car with all of the mentioned items at $13K firm. I don’t have to sell but I'm willing to turn the torch over to a new owner that will love this car as much as I do ( at the price listed of course)
I don’t have any current pix but will try to take some this weekend weather permitting. The car does not have tags or inspection so it would need to be trailered.
It can be street driven in it’s current configuration but I personally would rather to street drive it with the 400 engine vs the 462. The 462 MAY get 8 MPG with a light foot. It's a beast!! I used to attend the Muscle Car Challenge Series in the DFW area a few years ago. She will run consistent 12.00s in the qtr and will dip into the 11's if you can hook up. I can’t cut a light very well off the foot brake so I quit dumping money into traveling and fuel costs.
Please No Low Ballers, I know what I have. No Joy riders, I’m crazy not stupid.
Email me with questions. I’m slow to respond sometimes so have patience.
""Guitar groups are on the way out", "The Beatles have no
future in show business"
Decca Records rejection of The Beatles - 1962
Old 07-17-2009, 04:19 PM
Did you ever get the picture's of the undercarrige of the Black 74 Formula in Minnesota.Is the car as clean as it looks or were there some hidden issue's ? Please let me know. Thanks
Old 07-17-2009, 04:44 PM
Personally, I would pass. Unless he's come down a lot!
Old 07-17-2009, 06:58 PM
Did you actually go and look at the car ? If so was there anything major wrong ( besides the color change ) that would make you feel that way ? What do you think the car is worth ? Thanks in advance for any input.
