Old 03-24-2024, 05:14 PM
vicgto vicgto is offline
Default Auburn 546033 Cone type differential,
Is anyone running the Auburn 546033 Cone type differential on their 12 bolt. Is it reliable, any issues with the cones not locking? The picture shows that it's a 4 pinion, is this correct, how do you get the C clips in?
1972 GTO
468 2 Bolt Main w/Eagle rotating assy
SD Ported 295 KRE D Ports 10.8 CR
OF Hydraulic roller w/ 1.65 stainless rockers
Performer RPM Intake
Holley 3310 780 Vacuum Secondary
TH400 with 10" Continental Convertor
8.2 BOP 4 pinion 10 Bolt with 3.36 gears
11.428/118.95/1.618
Old 03-24-2024, 06:37 PM
I don’t know anything about that unit but the axles may require that you use a C-clip eliminator kit.
Old 03-24-2024, 07:50 PM
AG's Avatar
AG AG is offline
With the options out there it would be the last posi I would buy. A TruTrac or clutch type would be better for longevity.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 03-24-2024, 08:10 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default Auburn in 10 Bolt BOP
no issues so far in my 10 Bolt with 3:08 gears
gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, DUI HEI and Ram Air pans and RARE Long Branch Manifolds
Old 03-24-2024, 08:43 PM
Formulajones's Avatar
I've had one of those cone style Auburns in one of the 12 bolts here for what has to be 25 years or so. Has worked fine all that time with a lot of drag strip passes and burnouts. I've noticed it's starting to show it age though when I'm on a prepped track sometimes it slips and spins one tire. On the street it's fine.
Biggest issue with those is they aren't rebuildable so it's destined for a door stop.
If clutch style units are what you're looking for I prefer the Eaton units, as they are rebuildable and parts still available for them. Tru Trac's are nice and I use them in a couple cars. My only complaint is they don't offer a 12 bolt 4 series Tru Trac for 30 spline axles. I either have to go up to 33 spline axles or drop the gear down to a 3 something for the 3 series carrier.
https://youtu.be/XqEydRRRwqE
Old 03-24-2024, 09:10 PM
455dan's Avatar
455dan 455dan is offline
This is info from Kern Osterstock many, many years ago.
The Cone style has one advantage and that is not losing control 'as easily' in a corner where the car is at the traction limit. By backing out of the throttle the cones release allowing the tires to track through the turn. The Eaton unit using springs and clutch plates is less forgiving at the limit and will attempt to keep the tires locked together. This as to why H-O racing went to the trouble of modifying a GTO 4 pinion auburn cone style '10 bolt" and chose it for use in their second gen TA that H-O built for street strip use.
The axle bearings are pressed on as is the bearing retainer, so no c clips inside the 3rd member. YMMV
1984 RX7 Jim Hand style 455 /200 4R Project car
67 White/Gold GTO 4 speed sold, 1968 GTO 4 speed sold, 1969 GTO auto sold, 68 Firebird 400 4 speed (455) sold, 65 GTO Night Watch Blue 4 speed sold, 64 GTO Nocturne Blue 4 speed sold, 71 GTO Gold auto sold. 1975 Formula 400 auto sold.
Hopefully to be restored, H-"O" Racing 73 Trans Am SD 4 speed,
Sons 70 Formula 400 auto, and wife's 1974 AMX 360 auto, 1975 Jeep Honcho 4x4, 1965 Buick Special post
Old 03-25-2024, 10:40 AM
Steve C. Steve C. is online now
At one time Auburn had an exchange program for a new unit. Send it in and for a modest fee they would provide a new one, this to counter the bad rap that they are not rebuildable.
For years I ran a Auburn unit in my heavy TA running into the 10's. When we switched motors and decided to play with nitrous we installed a spool. At that time I sent the Auburn unit back to the factory under their exchange program and they sent me a brand new one for a very modest service fee. No more nitrous and that Auburn unit is currently in my car now with the 505 street motor which is still capable of running 10's.
Rear end: GM 12-bolt, Moser 30-spline axles, 3.73:1 gears, Auburn posi.
Old information here:
The Following User Says Thank You to Steve C. For This Useful Post:
