Old 07-17-2020, 07:19 AM
Bob Timmermans's Avatar
Bob Timmermans Bob Timmermans is offline
Question Proximity starterwire to headers.
The 1/4" of distance between this connection worries me and is making me consider a remote solenoid , so this isn't 'hot' all the time.
Am I worried about nothing or is this valid ?
ID:	545147   Click image for larger version
Old 07-17-2020, 08:43 AM
Scott65's Avatar
Scott65 Scott65 is offline
There's no real reason NOT to run the remote solenoid, but several good reasons to run one. I would and do.
Old 07-17-2020, 10:25 AM
Sirrotica's Avatar
The remote solenoid will keep the starter/battery cable connection from being "hot" all the time. I would also suggest a heat barrier wrap to further insulate the electrical from the header, and to shield some of the radiant heat transfer from the header.
Pontiac street cars with headers tend to have heat soak problems with the starters, shielding them will usually promote better hot starts as well as lengthen the longevity of the starter....FWIW
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 07-18-2020, 06:40 AM
Cool
I'm going to install the remote solenoid and wait and see if problems occur .
If so I'll deal with it later.
I have to say there are little aftermarket parts that don't need any modifications to make 'm work on your car .
Kinda gets frustrating at times , you think you finish one job and you end up doing 3.
Ah well , that's the hobby I guess . . . just me getting older and losing my patience with manufacturers.
Cheers , Bob.
Old 07-18-2020, 10:26 AM
stellar stellar is offline
As long as the headers don't move, a 1/4 inch is as good as a 1/4 mile. You could put a rubber boot over it. I don't think you will have a heat soak problem with that type of starter.
Old 07-18-2020, 01:09 PM
george kujanski's Avatar
george kujanski george kujanski is online now
If nothing moves, i would feel ok with just a rubber boot over the stud. You need something there.....think about dropping a wrench or a bolt...your battery may well explode, it's a direct short. certainly melt the cable and possibly start a fire.
George
Old 07-18-2020, 04:56 PM
A dealer should have boots for that type of starter. Honda Toyota Chrysler Subaru.
Old 07-19-2020, 08:10 AM
Question Solenoid modification.
I can't help but being naturaly curious.
So decided to have a look at my options with this thing.
Put it on the bench and unbolted the solenoidcap and see that the connection on the other side looks pretty much like the opposite.
Now , can I just put the battery cable on that side and shorten the opposite connector bolt to cover it up with a cap ?
ID:	545235   Click image for larger version
ID:	545236   Click image for larger version
Old 07-19-2020, 09:27 AM
I would leave well enough alone. and do a search of this Number 028062-0130. That may work for you. You don't want to put the battery cable on the other post. Not going to work. The solenoid pull in winding is connected to the shorter motor post. Search that number
Old 07-19-2020, 10:33 AM
66beaumont's Avatar
66beaumont 66beaumont is offline
If you put battery cable to short post that is direct feed to motor. Motor will run as soon as battery is connected
69 gto ,all#match,467,th400,3:55 Easton posi,resto completed may 2016. 427 hp/530tq. Stump puller with stock#62 , stock intake and qjet
Th400 gone. Tkx close ratio with .64 of
66 Pontiac Beaumont sport deluxe,BB 5sp tko 3:08 auburn 450hp 550 torque wife sold it
Old 07-19-2020, 12:50 PM
Bob,
How would you do the two different solenoid wires?
S terminal on the starter needs to work before power goes to the motor and secondary pull-in. If not the starter will spin before gear engagement.
I could see this working if you energize starter S first and then apply power to remote solenoid S while starter S is hot.
Remote S only would cause a lot of gear grinding.
Make sense?
Clay
Old 07-19-2020, 01:10 PM
Originally Posted by "QUICK-SILVER" View Post
Bob,
Make sense?
Clay
I've got the original instructionsheet from the Powermaster 9510 and it reads : " Can I use a remote solenoid ? Yes .
Connect the battery cable from the remote solenoid to the starter in the normal way.
Connect the starter's solenoid switch to the remotesolenoid switch terminal. "
So I guess I got this covered. Not shure on the battery cable to the other side tough.
Old 07-19-2020, 02:20 PM
Wired per directions the solenoid would kick the gear out before the starter got power and spun.
Moving the battery cable to the other side would make the starter spin before the gear kicked out. Good way to tear up starter drives and grind up ring gear teeth.
Could be done if you power up the starters solenoid wire before the remote solenoid was activated.
Don't know a good or easy way to do this
Clay
Old 07-19-2020, 02:54 PM
Default hook up
remote solenoid hook up. No power to starter battery post except when cranking.
Name:	remote solenoid 003.JPG
Old 07-20-2020, 05:16 AM
Geoff Geoff is offline
Remote relay [ not a sol, not needed ] is a good idea for a few reasons. Most important is it isolates the live terminal on the starter so that it is only 'live' when cranking. Also, the heavy sol [ sol on the starter ] current no longer travels around the world getting voltage drop through neutral switch, ign sw, bulkhead connectors etc. Life is also easier for the ign sw [ see below ] because it no longer is switching 40 amps, just a fraction of an amp.
There is NO need for a bulky sol. The original Ford type sols were reqd for some Ford starters that did not have a sol mounted on the starter.
All you need is a 60 amp relay, small & compact, only slightly larger than the popular 30 amp Bosch relay. I can buy them here for $10 & I have one on my GTO.
Old 07-20-2020, 11:39 AM
Thumbs up
I'ts allready on its way to my address , thanks.
Old 07-20-2020, 01:18 PM
Lee's Avatar
Lee Lee is offline
Just hammer the header tube a bit, and you'll easily have 1/2"+ of clearance.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
My webpage http://lnlpd.com/home
Old 07-20-2020, 02:11 PM
Bill Hanlon's Avatar
Bill Hanlon Bill Hanlon is online now
Hammer it until it breaks, then back off 1 hammer swing.
