Old 07-21-2020, 03:41 PM
Dick Boneske's Avatar
Default GTO Radio Antenna on Boat--not car related
I have a '64/65 A body antenna assy. left over from my two restorations. Would a car antenna work well on a fiberglass boat for a Pioneer AM/FM radio? The 36" wire supplied by Bayliner for the radio antenna is horrible.
Is there an issue with car-type antennas on a fiberglass boat due to the lack of a metal mounting surface (ground)?
IN any case, what's the best way to get decent radio reception on my boat?
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 07-21-2020, 08:09 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
Those antennas are not easy to find Dick. Sell it and buy a cheap aftermarket one for your boat.
Old 07-23-2020, 10:22 PM
The antenna I refer to is not suitable for a GTO restoration. My question is about function, not worried about anything else.
BONESTOCK GOATS
Old 07-23-2020, 11:28 PM
Chris65LeMans's Avatar
Chris65LeMans Chris65LeMans is online now
I don't see why not. I've never dealt with an antenna that needed to be "grounded."
Old 07-24-2020, 09:31 AM
george kujanski's Avatar
Interesting question.....I would think a ground plane is more important for a transmitting antenna than a receive-only antenna. Corvettes are essentially the same as boats... anyone know if the is a metal plane embedded under the glass?
I installed an antenna on my boat, seems to work ok in a metro area say 60 mile radius. I believe some OEM boats just have a hidden radio antenna.
George
Old 07-24-2020, 07:21 PM
I'd think the base of the antenna would have all the ground it needs (if needed) through the shield in the coax cable.
I do know they work fine when not mounted.
Clay
The Following User Says Thank You to "QUICK-SILVER" For This Useful Post:
