Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 07-28-2020, 06:34 PM
Entropy11's Avatar
Entropy11 Entropy11 is offline
Default 6X-4 Heads
Had these ready for my previous engine before things changed directions and was able to get a correct year block & heads For my GTO.
6X-4 Heads fresh from the machine shop. New Ferrea intakes, multi-angle, bronze guides, new Comp 995’s. Sold to me as 89cc, but I can cc again to verify.
Some mild Intake & exhaust port work as evidenced in pics (I Can try to get better pics showing extent).
Dates: B098 & D178
$975
Located in Western NY, can ship if needed.
ID:	545977   Click image for larger version
ID:	545982   Click image for larger version
ID:	545983   Click image for larger version
ID:	545984   Click image for larger version
Old 07-28-2020, 06:51 PM
roy381 roy381 is offline
Default heads
Are the exhaust valves stock size 1.66 or are they 1.77?
Old 07-28-2020, 09:52 PM
Entropy11's Avatar
Sorry, I should have mentioned 2.11 / 1.66
Old 07-30-2020, 03:55 PM
Entropy11's Avatar
Price drop from $975 to $900.
Need to order my trans soon and it’s not cheap! Lol
Old 08-04-2020, 12:31 AM
Tim Corcoran's Avatar
Tim Corcoran Tim Corcoran is online now
Are the valves stock length or are they the longer RA4 length valves. Do you know the installed height?
Tim Corcoran
Old 08-04-2020, 04:54 PM
Entropy11's Avatar
I bought the heads as built, with plans of installing the springs i wanted to use, so I’m unsure of the installed height. The valves should be stock length from what I was told prior to purchase.
I can get you the installed height measurement but it’ll take me a few days. Although the heads are sitting here ready to ship, 90% of my tools are packed away as we move from one house to the next over the next week or so.
Thx
Old 08-04-2020, 08:00 PM
If the valves are stock length then don't bother getting the installed height
Tim Corcoran
Old 08-15-2020, 03:14 PM
Entropy11's Avatar
Price drop to $800
Old 08-16-2020, 01:17 AM
Brian Baker's Avatar
I'm not aware that Ferrea makes stock length valves in the 1-piece stainless (which is what these look like). The 995 spring is designed to be installed at 1.700" which no stock length valve will accommodate, so it's a pretty safe bet that these are longer valves for the taller installed height that will handle upwards of a .600" lift flat tappet cam.
Old 08-16-2020, 01:36 AM
Entropy11's Avatar
Thanks for that info. It sure sheds some light on what’s in them. I purchased them as they sit now so had no specifics on them other than a general parts list where they mentioned New Ferrea Intake Valves.
I really appreciate your info. Thank you.
Old 09-06-2020, 02:16 PM
Entropy11's Avatar
Just pulled the valves today. Valve length: 4.980 Installed Height: 1.68 (No shims)
Make an offer on the whole thing or just the bare heads if you’d rather use your own valves/springs. Maybe somebody would be interested in the valves/springs after the heads go.
