Old 08-04-2020, 01:33 PM
highrisk's Avatar
highrisk highrisk is offline
Default Battery Ground to Thermostat Housing?
I currently run my battery ground to a studded bolt on the thermostat housing. This is a very convenient location which is easy to get to and I get a really good ground there. Is it a bad idea to run your main ground there because of the radiator fluid or does it really matter?
Dale
Tremec 5 Speed
U.S. Army Retired
Retired Helicopter Pilot
Old 08-05-2020, 12:30 AM
How many times have you seen a thermostat housing removed and seen corrosion under and around it. also how often have the bolts rusted into the manifold because of fluid getting past the gasket. No this is not a good place to ground your engine.
Old 08-05-2020, 07:48 AM
highrisk's Avatar
Thanks for the information and advice.
Dale
Tremec 5 Speed
U.S. Army Retired
Old 08-07-2020, 09:32 PM
Andretti's Avatar
Andretti Andretti is offline
GM mounted their ECM ground harnesses to the TStat housings on their 4th generation Caprice/Roadmasters (91'-96'). I remember numerous performance problems with them, even affecting the charging system. Got to the point where it was one of the first things you looked at during diagnosis.
Old 08-07-2020, 10:23 PM
highrisk's Avatar
Yeah, I did not think of the corrosion problems when I put it there. I have already moved it to a spare threaded hole on the front of the left head, right behind the alternator.
Dale
Tremec 5 Speed
U.S. Army Retired
